简介
This guide will show how to remove the battery from the Kindle Fire HD 6. You'll often need to remove the battery just to access and remove the motherboard. You might also need to remove the battery if it's damaged and needs to be replaced.
你所需要的
Place the device face down on a clean cloth or another smooth surface.
Insert the plastic opening tool between the device’s front and back panels. You might need to wiggle the tool up and down to wedge it in the gap.
Maneuver the tool around the device until the back unclips from the front panel.
Remove the multi-colored connector that joins the battery and the motherboard by pulling it straight up.
Remove the battery.
What if the connector on the motherboard to the battery got damaged in the process of removing the battery?
18等其他人完成本指南。
2条评论
Thank you it worked for me.
A bit nervous breaking it down, once I got the back plate off it was very simple, unplugged the battery, reconnected put it back together fired it up , great advice.
Thanks again
Regards
Terry
terry pils - 回复
The battery removal step did not sufficiently warn about how hard the adhesive used for the battery was, and using the spudger ended up piercing the battery when I tried to pry the battery off.
I wasn't sure that I would be able to fix my kindle. I did purchase another kindle, which was alright. I wanted a second kindle so with the purchase and my old one know fixed I am really glad. I feel if I have any future problems I will be able to fix it myself.
RUBY PEOPLES - 回复
i had a battery that wouldn't even last a full day in the end. by accident i let the battery fall below 10% charge and when turned on it only showed the battery icon. I fully charged it and now i am having no problems with it. what i think happened is it reset the batteries memory and that was the problem. worth trying anyway before buying a new battery.
soupamanx - 回复
