跳转到主内容
加入维修社区 - 创建账户
Kindle Fire HD 6 Back Panel Replacement
你所需要的
  1. Kindle Fire HD 6 Back Panel Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Place the device face down on a clean cloth or another smooth surface.
    • In the following steps, you will need to apply some force to your device. If your device is on a rough surface, you may scratch the screen.
    • Insert the plastic opening tool between the device’s front and back panels. You might need to wiggle the tool up and down to wedge it in the gap.
    • Maneuver the tool around the device until the back unclips from the front panel.
  2. Kindle Fire HD 6 Back Panel Replacement: 步骤 2 中的图像 1,2 Kindle Fire HD 6 Back Panel Replacement: 步骤 2 中的图像 2,2
    • Carefully separate the back panel from the rest of the device internals.
结论
2等其他人完成本指南。
000
于01/11/15注册
976 声望
撰写一个指南
团队
Cal Poly, Team 70-4, Forte Winter 2015 Cal Poly, Team 70-4, Forte Winter 2015 的会员
CPSU-FORTE-W15S70G4
4 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 32
总计 2,237
