跳转到主内容
Kindle Fire HD 2013 Screen Replacement
你所需要的
  1. Kindle Fire HD 2013 Screen Replacement, Screen: 步骤 1 中的图像 1,3 Kindle Fire HD 2013 Screen Replacement, Screen: 步骤 1 中的图像 2,3 Kindle Fire HD 2013 Screen Replacement, Screen: 步骤 1 中的图像 3,3
    • Open up the device by using a plastic opening tool in order to avoid damaging the device.
    • To do so, find the seam along the outer edge of the device and use the plastic tool to pry the back panel up. Doing so may take some force and patience.
  2. Kindle Fire HD 2013 Screen Replacement: 步骤 2 中的图像 1,2 Kindle Fire HD 2013 Screen Replacement: 步骤 2 中的图像 2,2
    • Before we can reach the screen, we must remove the plate that holds the rest of the components.
    • To do so, locate and remove the (10) 3mm T4 Torx screws highlighted.
    • There are also two ribbons connected the main device to the screen. To remove these, follow the ribbon to where they connect and use the spudger or a finger nail to lift the tab. Once open, gently pull the ribbon out.
  3. Kindle Fire HD 2013 Screen Replacement: 步骤 3 中的图像 1,1
    • After locating the USB port at the top of the device, remove the (2) 3mm T4 Torx screws.
  4. Kindle Fire HD 2013 Screen Replacement: 步骤 4 中的图像 1,1
    • After locating the Aux port at the bottom of the device, remove the (2) 3mm T4 Torx screws.
  5. Kindle Fire HD 2013 Screen Replacement: 步骤 5 中的图像 1,3 Kindle Fire HD 2013 Screen Replacement: 步骤 5 中的图像 2,3 Kindle Fire HD 2013 Screen Replacement: 步骤 5 中的图像 3,3
    • Once the screws and ribbons are removed, use the nylon spudger to gently remove the plate holding the rest of the components and set to the side.
    • Once the plate has been removed, located the (4) 3mm T4 Torx screws and remove them.
    • There is a single ribbon here that has to be removed as well. Follow the ribbon to where it connects. Gently lift the tab using the spudger or a fingernail. Once the tab is open, gently pull the ribbon out and away.
  6. Kindle Fire HD 2013 Screen Replacement: 步骤 6 中的图像 1,2 Kindle Fire HD 2013 Screen Replacement: 步骤 6 中的图像 2,2
    • Once the ribbon and screws are removed, pick the part up and tilt it into your other hand. The touch screen component and the clear cover should now be disconnected completely.
结论
7等其他人完成本指南。
aaa
于10/06/16注册
733 声望
创作了5篇指南
团队
USF Tampa, Team 2-3, Sullivan Fall 2016 USF Tampa, Team 2-3, Sullivan Fall 2016 的会员
USFT-SULLIVAN-F16S2G3
4 名成员
创作了6篇指南
一条评论
HI CAN U HELP WHERE TO BUY THE LCD AND DIGITIZER FOR THIS MODEL THANK YOU PLS EMAIL me
robert.vanderas@gmail.com
robert vanderas - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 24
总计 4,518
