跳转到主内容
Kindle Fire Back Case Replacement
你所需要的
  1. Kindle Fire Back Case Replacement, Back Case: 步骤 1 中的图像 1,3 Kindle Fire Back Case Replacement, Back Case: 步骤 1 中的图像 2,3 Kindle Fire Back Case Replacement, Back Case: 步骤 1 中的图像 3,3
    • Wedge a plastic opening tool into the lower right corner of the Kindle Fire.
    • Pry the case apart and run the plastic opening tool along the perimeter of the Kindle Fire to release the clips securing the case halves to each other.
    • If you are having extreme difficulty inserting the plastic opening tool, carefully use a metal spudger to undo the first clip, then switch back to the opening tool to avoid scratching your case.
    • It is helpful to pry the bottom of the Kindle Fire away (and out from the side) from the top part. Exerting too much force attempting to split the two without pulling away can cause the tabs on the inside to crack.
  2. Kindle Fire Back Case Replacement: 步骤 2 中的图像 1,1
    • Once you have freed all the plastic clips, pull the back case off the Kindle Fire.
结论
14等其他人完成本指南。
Phillip Takahashi
于08/22/11注册
86,704 声望
创作了87篇指南
3条评论
Simple to follow instructions .
Eric Rester - 回复
where to buy the base panel for my kindle fire 7 tablet
Senthilvel Murugesan - 回复
I was wondering why my kindle case was opening/separating and it was not charging. I opened the case per you instructions and found that the battery has expanded inside ITS case! I hope to be able to get another battery cheaply. Thank you for your help!!
Ellen De - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 56
总计 15,915
