跳转到主内容
Kindle Fire 1st Generation Motherboard Replacement
你所需要的
  1. Kindle Fire 1st Generation Motherboard Replacement, Removing The Back Cover: 步骤 1 中的图像 1,2 Kindle Fire 1st Generation Motherboard Replacement, Removing The Back Cover: 步骤 1 中的图像 2,2
    • May need to use something to pry it open such as a screwdriver.
    • After you pop some of the little clips inside, you can use your fingers to remove it completely.
  2. Kindle Fire 1st Generation Motherboard Replacement, Locating Part Number: 步骤 2 中的图像 1,3 Kindle Fire 1st Generation Motherboard Replacement, Locating Part Number: 步骤 2 中的图像 2,3 Kindle Fire 1st Generation Motherboard Replacement, Locating Part Number: 步骤 2 中的图像 3,3
    • The first photo shows two red circles over the screw that will need to be removed first.
    • After lifting the tab as shown in the third photo you will need the part number located below bar code.
  3. Kindle Fire 1st Generation Motherboard Replacement, Remove All Tabs: 步骤 3 中的图像 1,1
    • Next you will need remove all of the little white sliders that hold tabs down. if your fingernails are any shorter than mine you may need to use something for assistance.
  4. Kindle Fire 1st Generation Motherboard Replacement, Remove All Wires: 步骤 4 中的图像 1,3 Kindle Fire 1st Generation Motherboard Replacement, Remove All Wires: 步骤 4 中的图像 2,3 Kindle Fire 1st Generation Motherboard Replacement, Remove All Wires: 步骤 4 中的图像 3,3
    • Remove all of the wires that trace to the mother board.
    • Two speaker wires
    • Wire for battery
  5. Kindle Fire 1st Generation Motherboard Replacement, Removing The Last Few Pieces: 步骤 5 中的图像 1,3 Kindle Fire 1st Generation Motherboard Replacement, Removing The Last Few Pieces: 步骤 5 中的图像 2,3 Kindle Fire 1st Generation Motherboard Replacement, Removing The Last Few Pieces: 步骤 5 中的图像 3,3
    • Using your fillips screwdriver, remove the screws that have red circles around them.
    • The screws that have blue circles around them should already be removed at this point but there are two remaining screws under that tab that also need to be removed.
    • In addition, use your fingers to remove the tab that has a purple square around it.
  6. Kindle Fire 1st Generation Motherboard Replacement, Pull The Mother Board Out: 步骤 6 中的图像 1,1
    • Pull the motherboard out and order the part.
结论
Reed
于03/06/18注册
133 声望
撰写一个指南
团队
Vegas Room H9 Vegas Room H9 的会员
Community
13 名成员
创作了17篇指南
一条评论
Hey! how did you manage to pry the back off?
Ben Sommer - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 20
总计 452
