简介
本指南帮助你更换Amazon Kindle Fire的电池。
你所需要的
一旦你将所有塑料卡扣解锁,拉动后壳,使其与 Kindle Fire分离。
在电池的左侧重复先前的操作。
The CPU got extremely hot and just now getting repaired 5 days or so
I can't get the battery to charge
重新组装您的设备时,请按照相反的顺序执行这些指示。
80等其他人完成本指南。
由衷感谢以下译者:
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
12条评论
I'm usually intimidated by electronics when it comes time to pull off the back or something, so this guide was invaluable in my efforts to replace the battery. I found a great price ($28) on a replacement Kindle battery here: http://www.primelec.com/atl-tablet-eread...
Thanks again
great post, I came across http://bestbattery.biz/Amazon/189882-D01...
The batteries from bestbattery.biz tried and tested with us.
Used this guide to replace my battery. Sadly, it didn't fix the problem. The problem is with my charger connection. It is loose. I had hoped changing the battery and looking at the problem from the inside would resolve it. The charging connection is in it's own little housing. I considered opening the housing but I had no replacement parts to fix whatever may be wrong. I greatly appreciate the quality of this repair guide. There were no problems with tear down or putting back together. Thanks again!
Some kindles have a battery connection that "floats". The problem can be alleviated by soldering the charging port. There is an excellent video on YouTube that shows step by step, the process for soldering the charging port. Hope this helps!!!
Kindle Fire will not charge and when I wiggle the cord to charge the Kindle the light comes on but doesn't stay on. Tried a different cord still does not work. Where can I get another battery for the Kindle Fire. Please let me know or any Barnes and Noble bookstore or Staples, or Office Depot store where I can find a battery. Thanks Melony
Easy Peary!! To remove the battery that is. Thanks!!!
Jane Elder - 回复
Very helpful post. Thanks. Anyone interested in considering buying a refurbished kindle from amazon. Read some interesting facts here http://rodsmarketingsite.com/7-reasons-t...
I tried this to replace the battery but backed out because the pictures looked far different from my Kindle Fires inside and I was afraid of messing something it up. Still a really good guide.
Where can I buy a battery for my kindle fire
nannyto2 - 回复
Try EBay or Amazon. make sure you get the right battery for your Kindle , one is for a Kindle HD and the older version........both are 7 ".
vvenona1954 - 回复
Remember to remove any sd card first!!! Snapped mine in half.
lucy_lady_bug - 回复
I have the first kindle that came out and it doesn't have the same setup how can I open the back of my kindle?
Kris Sanders - 回复
