跳转到主内容
加入维修社区 - 创建账户
Kindle 7th Generation Front Panel Replacement
你所需要的
  1. Kindle 7th Generation Front Panel Replacement, Front Panel: 步骤 1 中的图像 1,2 Kindle 7th Generation Front Panel Replacement, Front Panel: 步骤 1 中的图像 2,2
    • Power off your Kindle before beginning disassembly.
    • At each corner, use the blue plastic opening tool to unhook and separate the front panel from the adhesive.
    • Run the tool along the seams to pry open the front panel.
  2. Kindle 7th Generation Front Panel Replacement: 步骤 2 中的图像 1,1
    • Peel the front panel off to remove it from the Kindle.
    • If this is the first time the front panel has been removed, the adhesive may require a significant amount of force to undo.
    • To prevent damaging the front panel, peel the panel from the corners towards the middle of the Kindle.
    • When reassembling your device, if you are replacing the front panel, additional adhesive may be required.
结论
4等其他人完成本指南。
Abby Roulier
于02/08/15注册
1,095 声望
创作了3篇指南
团队
Cal Poly, Team 6-28, Amido Winter 2015 Cal Poly, Team 6-28, Amido Winter 2015 的会员
CPSU-AMIDO-W15S6G28
4 名成员
创作了26篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 54
总计 6,034
