跳转到主内容
Kindle 7th Generation Back Panel Replacement
你所需要的
  1. Kindle 7th Generation Back Panel Replacement, Front Panel: 步骤 1 中的图像 1,2 Kindle 7th Generation Back Panel Replacement, Front Panel: 步骤 1 中的图像 2,2
    • Power off your Kindle before beginning disassembly.
    • At each corner, use the blue plastic opening tool to unhook and separate the front panel from the adhesive.
    • Run the tool along the seams to pry open the front panel.
  2. Kindle 7th Generation Back Panel Replacement: 步骤 2 中的图像 1,1
    • Peel the front panel off to remove it from the Kindle.
    • If this is the first time the front panel has been removed, the adhesive may require a significant amount of force to undo.
    • To prevent damaging the front panel, peel the panel from the corners towards the middle of the Kindle.
    • When reassembling your device, if you are replacing the front panel, additional adhesive may be required.
  3. Kindle 7th Generation Back Panel Replacement, Back Panel: 步骤 3 中的图像 1,2 Kindle 7th Generation Back Panel Replacement, Back Panel: 步骤 3 中的图像 2,2
    • Remove the ten 5.0 mm T5 Torx screws.
    • A magnetized screw mat can help you keep track of your screws.
  4. Kindle 7th Generation Back Panel Replacement: 步骤 4 中的图像 1,1
    • Working evenly along the corners and edges, separate the internal contents from the back panel.
    • There are many clips securing the screen to the back panel. Force will be required to remove the back, but you should never feel that the Kindle may break.
结论
4等其他人完成本指南。
Abby Roulier
于02/08/15注册
948 声望
创作了3篇指南
团队
Cal Poly, Team 6-28, Amido Winter 2015 Cal Poly, Team 6-28, Amido Winter 2015 的会员
CPSU-AMIDO-W15S6G28
4 名成员
创作了18篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 12
过去 30 天: 38
总计 4,809
