此翻译由机器生成,尚未经过人工审核。 会说这种语言吗? 查看评论。
你所需要的
21等其他人完成本指南。
10指南评论
Es sollte m.E. noch ergänzt werden, dass der Deckel an den schmalen Seiten mit je zwei Laschen gesteckt ist. Um den Deckel zu lösen, muss man, nachdem die langen Seiten wie beschrieben geöffnet wurden, ihn etwas nach außen wölben: Man zieht dazu die schmalen Seiten in Richtung der Gehäusemitte, so dass man die Laschen herausziehen kann.
By far the worst part is the battery cover is welded to the back of the case with gluonium which cannot be removed with anythhng but gamma rays and kryptonite, so as the guide says,, long thin knife is what you need. The battery is glued in the same but you don’t care so much at this point :-) See step 3, the tabs top and bottom, you remove the cover by flexing it away from the frame at about the mid point.
Time and patience, gently, gently teasy monkey…
Just an idea for removing the well-glued-in battery - I use slivers of bamboo from the side of a largish cane, sanded to a thinnish blade. Not as strong as metal blades but non-conductive!
easiest way is to drop a few squirts of alcohol next to the battery, wait for 30 seconds to let it get behind the cell and then use a bank card or so to prize it loose, ideally a non-conductive thing. its easy as pie, the double-sided tape loosens, and the unit can just be pushed out with the card.
