简介
This guide covers the basic steps to replace the screen on the First Generation Amazon Kindle.
你所需要的
Remove the two (2) Phillips #00 screws (3 mm) connecting the ON/OFF Power and Wifi Switches.
Lift the flap attaching the blue and white ribbon cable to the motherboard by lifting it vertically with the spudger.
Lift the flap with the pointed-end of the spudger to detach the ribbon cable indicated in the second image.
Use tweezers to pull the ribbon cable in the third image laterally to detach it.
Remove the two (2) Phillips #00 screws (3 mm) which attach the motherboard to the front casing.
Carefully lift the motherboard off.
The piece marked in the third image may be loose and fall out freely. If it does not fall off, use your fingers or a plastic opening tool to snap it off. Make sure to place it under the motherboard during reassembly, as found in the image.
The keyboard and the blue and white ribbon cable will slide out horizontally from behind the frame.
The rubber key pads will slide out from behind the frame.
Use a spudger to pry the two white tabs off the edge of the metal frame. This will separate the front cover from the metal frame.
Use a spudger to break the adhesive holding the front cover onto the screen by sliding it slowly around the edges just underneath the front cover.
6等其他人完成本指南。
