跳转到主内容
Kidzlane Walkie-Talkie Antenna Replacement
你所需要的
  1. Kidzlane Walkie-Talkie Antenna Replacement, Antenna: 步骤 1 中的图像 1,1
    • Flip your device over so the back panel is facing up.
  2. Kidzlane Walkie-Talkie Antenna Replacement: 步骤 2 中的图像 1,2 Kidzlane Walkie-Talkie Antenna Replacement: 步骤 2 中的图像 2,2
    • Use the Phillips #00 Screwdriver to unscrew the four 4mm screws shown.
    • Take out the three batteries from the device.
  3. Kidzlane Walkie-Talkie Antenna Replacement: 步骤 3 中的图像 1,2 Kidzlane Walkie-Talkie Antenna Replacement: 步骤 3 中的图像 2,2
    • Gently separate the front and back panels of the device.
    • Gently remove the green circuit board and the black speaker from the plastic casing.
  4. Kidzlane Walkie-Talkie Antenna Replacement: 步骤 4 中的图像 1,1
    • Flip the green circuit board over, so that the end of the antenna is visible. Use the soldering iron to disconnect the antenna.
    • Carefully remove the antenna from the circuit board.
    • The antenna may be hot from the soldering device.
结论
To reassemble your Kidzlane Walkie-Talkie, follow these instructions in reverse order.
2等其他人完成本指南。
Amin
于02/13/16注册
642 声望
创作了5篇指南
团队
IUPUI, Team 1-1, Wilson Spring 2016 IUPUI, Team 1-1, Wilson Spring 2016 的会员
IUPUI-WILSON-S16S1G1
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 10
总计 964
