跳转到主内容
KidzLane Walkie-Talkie Press-to-speak button Replacement
你所需要的
  1. KidzLane Walkie-Talkie Press-to-speak button Replacement, Press-to-speak button: 步骤 1 中的图像 1,1
    • Place the Walkie-Talkie on a flat surface-preferably a table or a desk.
    • Flip the device over to where you see four screws in each corner.
    • Make sure you take out the batteries before proceeding.
  2. KidzLane Walkie-Talkie Press-to-speak button Replacement: 步骤 2 中的图像 1,2 KidzLane Walkie-Talkie Press-to-speak button Replacement: 步骤 2 中的图像 2,2
    • Using your Phillips head screwdriver, unscrew all four 4mm screws from each corner.
  3. KidzLane Walkie-Talkie Press-to-speak button Replacement: 步骤 3 中的图像 1,1
    • Once you have unscrewed all four corners, open the device so it will be in two parts.
    • As you're opening the inside of the Walkie-Talkie, don't break off any wires within the device.
    • Taking the Phillips head screwdriver again, unscrew the three screws on the circuit board (green plate).
    • Separate these screws from the other four since they are different sizes.
  4. KidzLane Walkie-Talkie Press-to-speak button Replacement: 步骤 4 中的图像 1,2 KidzLane Walkie-Talkie Press-to-speak button Replacement: 步骤 4 中的图像 2,2
    • Take the circuit board out of the plastic casing.
    • Use the soldering device to iron the silver box (press-to-speak button), and then remove it from the circuit board.
终点
2等其他人完成本指南。
Amin
于02/13/16注册
642 声望
创作了5篇指南
团队
IUPUI, Team 1-1, Wilson Spring 2016 IUPUI, Team 1-1, Wilson Spring 2016 的会员
IUPUI-WILSON-S16S1G1
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 6
总计 904
