跳转到主内容
Kid Galaxy Morphibians Explorer On/Off Switch Replacement
你所需要的
  1. Kid Galaxy Morphibians Explorer On/Off Switch  Replacement, Remove the Top Cover: 步骤 1 中的图像 1,1
    • First, completely loosen the 9.6 mm Phillips #2 screw on top. There is a plastic washer that holds the screw to the top cover, so it will not need to be taken out.
  2. Kid Galaxy Morphibians Explorer On/Off Switch  Replacement: 步骤 2 中的图像 1,1
    • After the screw has been loosened, lift the cover off.
  3. Kid Galaxy Morphibians Explorer On/Off Switch  Replacement: 步骤 3 中的图像 1,1
    • Completely loosen the 9.6 mm Phillips #2 screw from the battery cover. Once again, there is a plastic washer to hold the screw to the cover.
  4. Kid Galaxy Morphibians Explorer On/Off Switch  Replacement: 步骤 4 中的图像 1,1
    • After the screw is loosened, lift the battery cover off the top cover to gain access to the batteries.
    • Turn the RC car over to reach the six screws on the bottom.
  5. Kid Galaxy Morphibians Explorer On/Off Switch  Replacement: 步骤 5 中的图像 1,1
    • Remove the six 11.6 mm Phillips #2 screws on the bottom cover.
    • (Wheels are removed in this picture to clearly show screw location. They do not need to be removed for this step)
  6. Kid Galaxy Morphibians Explorer On/Off Switch  Replacement: 步骤 6 中的图像 1,1
    • Lift the top Cover off the car.
  7. Kid Galaxy Morphibians Explorer On/Off Switch  Replacement, On/Off Switch: 步骤 7 中的图像 1,1
    • On the top of the inside cover you will see the back side of the on/off switch. Remove the two 7.2 mm Philips #00 head screws holding the switch in place.
  8. Kid Galaxy Morphibians Explorer On/Off Switch  Replacement: 步骤 8 中的图像 1,1
    • Gently pull the on/off switch off the inside cover.
    • Remove the positive (red wire) and negative (black wire) terminals from the bottom of the batter cover. Snip the wires using wire cutters.
    • Remove to freed on/off switch from the inside cover.
结论
团队
USF Tampa, Team 1-2, Hickman Fall 2014 USF Tampa, Team 1-2, Hickman Fall 2014 的会员
USFT-HICKMAN-F14S1G2
3 名成员
创作了7篇指南
一条评论
In the last step, Step 8 second bullet. Could add a image of actually showing how its done.
Dishant Patel - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 458
