跳转到主内容
Kid Galaxy Morphibians Explorer Controller Internal Chip Replacement
你所需要的
  1. Kid Galaxy Morphibians Explorer Controller Internal Chip Replacement, Batteries: 步骤 1 中的图像 1,1
    • Turn the controller over to the backside and locate the battery cover screw.
  2. Kid Galaxy Morphibians Explorer Controller Internal Chip Replacement: 步骤 2 中的图像 1,1
    • The battery cover 8.0mm Phillips #2 screw is on the bottom left handle. There is a plastic washer holding the screw to the cover, so completely loosen the screw, but do not remove.
  3. Kid Galaxy Morphibians Explorer Controller Internal Chip Replacement: 步骤 3 中的图像 1,1
    • Once the screw is removed lift the battery cover up from the controller.
  4. Kid Galaxy Morphibians Explorer Controller Internal Chip Replacement: 步骤 4 中的图像 1,1
    • Remove the 2 AA batteries.
  5. Kid Galaxy Morphibians Explorer Controller Internal Chip Replacement, Internal Chip: 步骤 5 中的图像 1,1
    • Remove both 6.0mm Phillips #1 screws holding the D-pads in place.
  6. Kid Galaxy Morphibians Explorer Controller Internal Chip Replacement: 步骤 6 中的图像 1,1
    • Insert wisdom here.
  7. Kid Galaxy Morphibians Explorer Controller Internal Chip Replacement: 步骤 7 中的图像 1,1
    • Remove the six 8.1 Phillips #1 screws.
  8. Kid Galaxy Morphibians Explorer Controller Internal Chip Replacement: 步骤 8 中的图像 1,1
    • Lift the antenna holder away from the controller towards the top of the antenna.
  9. Kid Galaxy Morphibians Explorer Controller Internal Chip Replacement: 步骤 9 中的图像 1,1
    • Before you separate both halves of the controller make sure the battery holder is facing you so the D-pads stay in place.
    • Separate both halves of the controller.
  10. Kid Galaxy Morphibians Explorer Controller Internal Chip Replacement: 步骤 10 中的图像 1,1
    • Remove the 7.9 Phillips #1 screw that holds both the antenna and the internal chip.
  11. Kid Galaxy Morphibians Explorer Controller Internal Chip Replacement: 步骤 11 中的图像 1,1
    • Remove the internal chip by pulling it away from the controller.
    • Remove both the positive(red wire) and negative(black wire) from the battery terminals.
    • Reverse the steps to put everything back together.
结论
Rusbell Gonzalez
于09/17/14注册
219 声望
创作了5篇指南
团队
USF Tampa, Team 1-2, Hickman Fall 2014 USF Tampa, Team 1-2, Hickman Fall 2014 的会员
USFT-HICKMAN-F14S1G2
3 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 202
