跳转到主内容
修复你的物品
维修的权力
配件 & 工具
简介
There are only a few steps that you need to take in order to replace the batteries.
配件
没有特定配件。
  1. First, completely loosen the 9.6 mm Phillips #2 screw on top. There is a plastic washer that holds the screw to the top cover, so it will not need to be taken out.
    • First, completely loosen the 9.6 mm Phillips #2 screw on top. There is a plastic washer that holds the screw to the top cover, so it will not need to be taken out.
  2. After the screw has been loosened, lift the cover off.
    • After the screw has been loosened, lift the cover off.
  3. LCD iPhone 屏幕维修套装
    预算选项,涵盖在我们的终身保修中。
    购买套装
    LCD iPhone 屏幕维修套装
    削减维修成本,而不是质量。
    购买套装
  4. Completely loosen the 9.6 mm Phillips #2 screw from the battery cover. Once again, there is a plastic washer to hold the screw to the cover.
    • Completely loosen the 9.6 mm Phillips #2 screw from the battery cover. Once again, there is a plastic washer to hold the screw to the cover.
  5. Lift the battery cover to gain access to the batteries.
    • Lift the battery cover to gain access to the batteries.
    • Replace the 3 AA batteries and reverse the steps to put everything back together.
结论
Rusbell Gonzalez
于2014年09月17日注册
219 信誉积分
创作了5篇指南
团队
USF Tampa, Team 1-2, Hickman Fall 2014 USF Tampa, Team 1-2, Hickman Fall 2014 的会员
USFT-HICKMAN-F14S1G2
3 名成员
创作了7篇指南
添加评论
浏览统计数据:
过去的24小时: 1
过去的7天: 2
过去的30天: 13
总计 2,055
