跳转到主内容
Kicker CXA300.1 Capacitor Replacement
你所需要的
  1. Kicker CXA300.1 Capacitor Replacement, Capacitor: 步骤 1 中的图像 1,1
    • Remove the five T10 Torx screws from the housing.
  2. Kicker CXA300.1 Capacitor Replacement: 步骤 2 中的图像 1,1
    • Remove the two T10 Torx screws from the faceplate.
  3. Kicker CXA300.1 Capacitor Replacement: 步骤 3 中的图像 1,2 Kicker CXA300.1 Capacitor Replacement: 步骤 3 中的图像 2,2
    • Remove the six T10 Torx screws from the bottom.
    • Pull off the bottom.
  4. Kicker CXA300.1 Capacitor Replacement: 步骤 4 中的图像 1,1
    • Desolder the capacitor and remove.
    • Refer to iFixit’s soldering guide to reattach capacitor.
结论
Tim Keptya
于04/12/18注册
546 声望
创作了4篇指南
团队
UW Tacoma, Team S1-G3, Liner Spring 2018 UW Tacoma, Team S1-G3, Liner Spring 2018 的会员
UWT-LINER-S18S1G3
3 名成员
创作了4篇指南
一条评论
Are you out of your mind or was this a late April Fools joke?!? That is NOT how you replace a capacitor, all you did was tear one off the board and take pictures of the carnage.
To replace a through-hole or snap-in capacitor you need to remove the board from the heat sink and (de)solder on the under side. In addition, proper selection of your replacement parts is crucial to the long-term viability of your repair.
If you are replacing a leaky/ruptured capacitor (or in this case, one that’s been torn off the board by a caveman) it’s critical to thoroughly clean any areas of the board and all components that were exposed to the electrolyte. The electrolyte in electrolytic capacitors is corrosive and will destroy the circuit board if it is not removed.
Tim, I encourage a response. Lets get some dialogue going.
Matt - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 20
总计 861
