跳转到主内容
Keurig K70 Top Needle Replacement
你所需要的
  1. Keurig K70 Top  Needle Replacement, Handle: 步骤 1 中的图像 1,2 Keurig K70 Top  Needle Replacement, Handle: 步骤 1 中的图像 2,2
    • Locate the handle on top of the unit
    • Locate the two Torx head screws on the underside of the handle. Remove them with a T15 screwdriver
  2. Keurig K70 Top  Needle Replacement: 步骤 2 中的图像 1,3 Keurig K70 Top  Needle Replacement: 步骤 2 中的图像 2,3 Keurig K70 Top  Needle Replacement: 步骤 2 中的图像 3,3
    • Bend the handle outward to remove
  3. Keurig K70 Top  Needle Replacement, Top  Needle: 步骤 3 中的图像 1,1
    • While looking upwards from underneath the Keurig, remove the two 8mm Phillips #2 screws from underneath the black plastic "shroud".
    • Remove the black plastic "shroud" by pushing inwards and then pulling upwards to disengage the plastic hooks that are not visible.
  4. Keurig K70 Top  Needle Replacement: 步骤 4 中的图像 1,3 Keurig K70 Top  Needle Replacement: 步骤 4 中的图像 2,3 Keurig K70 Top  Needle Replacement: 步骤 4 中的图像 3,3
    • Remove the two 8 mm screws with a PH #1 screwdrver
    • Pull on the plastic tube to remove it
    • This will require a generous amount of force
  5. Keurig K70 Top  Needle Replacement: 步骤 5 中的图像 1,1
    • Remove the two 8mm screws with a PH #2 screwdriver.
  6. Keurig K70 Top  Needle Replacement: 步骤 6 中的图像 1,1
    • Pull out on the top component perpendicular to the top face as shown. It will pop out without too much effort.
    • The needle is now exposed on the bottom of the part being handled in this photo. Be careful where you grab this component, we recommend doing as we have done here. Grab the front "lip" of the component (see photo).
  7. Keurig K70 Top  Needle Replacement: 步骤 7 中的图像 1,1
    • This is the component that should detach after pulling down.
    • Be careful of the needle!
  8. Keurig K70 Top  Needle Replacement: 步骤 8 中的图像 1,1
    • On the bottom of the component is the exposed needle, which is now accessible.
    • If you remove the needle be careful as it may be sharp.
结论
2等其他人完成本指南。
Alec Foster
于10/06/16注册
161 声望
撰写一个指南
团队
Cal Poly, Team 20-4, Livingston Fall 2016 Cal Poly, Team 20-4, Livingston Fall 2016 的会员
CPSU-LIVINGSTON-F16S20G4
4 名成员
创作了5篇指南
2条评论
If the needle were sharp this wouldn’t be necessary.
Can a replacement ‘needle’ be purchased somewhere? This must be almost universal and should be easily obtainable from Keurig.
krrjr49 - 回复
Did you find a place to purchase a replacement top needle? All I can find is the bottom exit needle assembly.
Liz Mark - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 21
总计 4,022
