跳转到主内容
Keurig K55 Water Filter Replacement
你所需要的
  1. Keurig K55 Water Filter Replacement, Charcoal water filter: 步骤 1 中的图像 1,1
    • Soak the new charcoal filter in water for 5 minutes.
  2. Keurig K55 Water Filter Replacement: 步骤 2 中的图像 1,3 Keurig K55 Water Filter Replacement: 步骤 2 中的图像 2,3 Keurig K55 Water Filter Replacement: 步骤 2 中的图像 3,3
    • Remove the water reservoir from the Keurig machine by gently lifting up on the reservoir and pulling it away.
  3. Keurig K55 Water Filter Replacement: 步骤 3 中的图像 1,1
    • Remove the lid from the water reservoir and empty any remaining water from the tank.
  4. Keurig K55 Water Filter Replacement: 步骤 4 中的图像 1,2 Keurig K55 Water Filter Replacement: 步骤 4 中的图像 2,2
    • Remove water filter holder from within the water reservoir by pulling up on the holder and lifting it out.
  5. Keurig K55 Water Filter Replacement: 步骤 5 中的图像 1,2 Keurig K55 Water Filter Replacement: 步骤 5 中的图像 2,2
    • To remove the old filter, pinch both sides of the filter holder at the base and pull it apart. Remove the old filter by lifting it out of the filter holder.
    • Dispose of old water filter cartridge.
  6. Keurig K55 Water Filter Replacement: 步骤 6 中的图像 1,1
    • Take the soaked water filter and rinse it under running water for 60 seconds.
  7. Keurig K55 Water Filter Replacement: 步骤 7 中的图像 1,2 Keurig K55 Water Filter Replacement: 步骤 7 中的图像 2,2
    • Place new water filter cartridge into the upper filter holder.
    • Snap the bottom of the filter holder back on by aligning the tabs with the spaces
结论
另外一个人完成了本指南。
Maria Kostourkova
于06/20/18注册
160 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 21
总计 1,161
