跳转到主内容
简介
Is your Keurig K55 K lid not staying open? If so, you might have a broken or missing spring. Here's a guide to replace the Keurig K55 Lid Spring.
配件
没有特定配件。
  1. Lift the silver handle up. Locate the screw and washer holding the handle in place on each side. Remove both 13mm screws and washers using a Phillips #0 screwdriver.
    • Lift the silver handle up.
    • Locate the screw and washer holding the handle in place on each side.
    • Remove both 13mm screws and washers using a Phillips #0 screwdriver.
  2. Grab the handle and pull it upward and toward the rear of the device. Lift the lid to the fully open position.
    • Grab the handle and pull it upward and toward the rear of the device.
    • Lift the lid to the fully open position.
    • Remove the two 11mm Phillips screws located on the upper part of the device.
    • Be careful removing the screws; the needle here may be sharp.
  3. Lower the lid to just before its closing position. Grab the black top cover with the Keurig logo and gently push back toward the rear of the device to release it. Gently pull the top cover upward and toward the front of the device to remove it.
    • Lower the lid to just before its closing position.
    • Grab the black top cover with the Keurig logo and gently push back toward the rear of the device to release it.
    • Gently pull the top cover upward and toward the front of the device to remove it.
  4. Remove the two 11mm Phillips head screws securing the water pump. Grab the secondary water pump firmly and pull one of the plastic water lines off of the pump. Pull the other line from the water pump.
    • Remove the two 11mm Phillips head screws securing the water pump.
    • Grab the secondary water pump firmly and pull one of the plastic water lines off of the pump.
    • Pull the other line from the water pump.
  5. Pull the spring off the front hook using two fingers. The spring has a lot of tension, so grip the spring end tightly.
    • Pull the spring off the front hook using two fingers.
    • The spring has a lot of tension, so grip the spring end tightly.
  6. Pull the spring off the other hook. Pull the spring off the other hook.
    • Pull the spring off the other hook.
结论
另外一个人完成了本指南。
William O'Brien
于2018年01月23日注册
491 信誉积分
创作了4篇指南
团队
Cal Poly, Team S1-G3, Livingston Winter 2018 Cal Poly, Team S1-G3, Livingston Winter 2018 的会员
CPSU-LIVINGSTON-W18S1G3
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 19
总计 932
