跳转到主内容
加入维修社区 - 创建账户
Keurig K55 Lid Spring Replacement
你所需要的
  1. Keurig K55 Lid Spring Replacement, Secondary Water Pump: 步骤 1 中的图像 1,3 Keurig K55 Lid Spring Replacement, Secondary Water Pump: 步骤 1 中的图像 2,3 Keurig K55 Lid Spring Replacement, Secondary Water Pump: 步骤 1 中的图像 3,3
    • Lift the silver handle up.
    • Locate the screw and washer holding the handle in place on each side.
    • Remove both 13mm screws and washers using a Phillips #0 screwdriver.
    询问修复机器人
    添加评论
  2. Keurig K55 Lid Spring Replacement: 步骤 2 中的图像 1,2 Keurig K55 Lid Spring Replacement: 步骤 2 中的图像 2,2
    • Grab the handle and pull it upward and toward the rear of the device.
    • Lift the lid to the fully open position.
    • Remove the two 11mm Phillips screws located on the upper part of the device.
    • Be careful removing the screws; the needle here may be sharp.
    询问修复机器人
    添加评论
  3. Keurig K55 Lid Spring Replacement: 步骤 3 中的图像 1,3 Keurig K55 Lid Spring Replacement: 步骤 3 中的图像 2,3 Keurig K55 Lid Spring Replacement: 步骤 3 中的图像 3,3
    • Lower the lid to just before its closing position.
    • Grab the black top cover with the Keurig logo and gently push back toward the rear of the device to release it.
    • Gently pull the top cover upward and toward the front of the device to remove it.
    询问修复机器人
    添加评论
  4. Keurig K55 Lid Spring Replacement: 步骤 4 中的图像 1,3 Keurig K55 Lid Spring Replacement: 步骤 4 中的图像 2,3 Keurig K55 Lid Spring Replacement: 步骤 4 中的图像 3,3
    • Remove the two 11mm Phillips head screws securing the water pump.
    • Grab the secondary water pump firmly and pull one of the plastic water lines off of the pump.
    • Pull the other line from the water pump.
    询问修复机器人
    添加评论
  5. Keurig K55 Lid Spring Replacement, Lid Spring: 步骤 5 中的图像 1,2 Keurig K55 Lid Spring Replacement, Lid Spring: 步骤 5 中的图像 2,2
    • Pull the spring off the front hook using two fingers.
    • The spring has a lot of tension, so grip the spring end tightly.
    询问修复机器人
    添加评论
  6. Keurig K55 Lid Spring Replacement: 步骤 6 中的图像 1,2 Keurig K55 Lid Spring Replacement: 步骤 6 中的图像 2,2
    • Pull the spring off the other hook.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
团队
Cal Poly, Team S1-G3, Livingston Winter 2018 Cal Poly, Team S1-G3, Livingston Winter 2018 的会员
CPSU-LIVINGSTON-W18S1G3
4 名成员
创作了10篇指南
2指南评论
What is the small plastic/rubber angled water line part that the front part of the water pump valve is inserted into ?
Joe K - 回复 分享
Well i might have described it as a water pump in my above message, but from what I've read on here it is a check valve, so what is the rubber/plastic small angled water line part that the front of the check valve is inserted into !
Joe K - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 16
过去 30 天: 56
总计 2,549
