跳转到主内容
Keurig K40 Top Water Pump Replacement
你所需要的
  1. Keurig K40 Top Water Pump Replacement, Top Water Pump: 步骤 1 中的图像 1,1
    • Begin by removing the top cover from the device.
    • Remove the cover by gently rocking it back and forth with an emphasis on lowering the left side underneath an internal peg.
  2. Keurig K40 Top Water Pump Replacement: 步骤 2 中的图像 1,1
    • Unscrew both 1.5mm screws located on the water pump.
  3. Keurig K40 Top Water Pump Replacement: 步骤 3 中的图像 1,2 Keurig K40 Top Water Pump Replacement: 步骤 3 中的图像 2,2
    • Keeping one hand firmly placed on the device, tug upwards on the water pump until it is separated from the device.
    • The water pump and pipe should now be loose and easy to move as shown.
  4. Keurig K40 Top Water Pump Replacement: 步骤 4 中的图像 1,2 Keurig K40 Top Water Pump Replacement: 步骤 4 中的图像 2,2
    • Pull on the point where the pipe meets the water pump.
    • The pipe will come loose and the water filter will be free and ready to be replaced.
结论
5等其他人完成本指南。
团队
USF Tampa, Team 6-1, Eyestone Spring 2016 USF Tampa, Team 6-1, Eyestone Spring 2016 的会员
USFT-EYESTONE-S16S6G1
3 名成员
创作了5篇指南
4条评论
I NEED ONE OF THESE! Where can I find one????
G Steve - 回复
This is a check valve, not the water pump.
Rick Koen - 回复
Please rename this article. The item is not a water pump.
tvyse46 - 回复
I viewed this to replace the pump. But after the checkvalve was replaced through these instructions my K40 works like new. Thank you.
Glenn Stanley - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 49
总计 9,386
