跳转到主内容
Keurig K40 Open/Close Sensor Replacement
你所需要的
  1. Keurig K40 Open/Close Sensor Replacement, Top Water Pump: 步骤 1 中的图像 1,1
    • Begin by removing the top cover from the device.
    • Remove the cover by gently rocking it back and forth with an emphasis on lowering the left side underneath an internal peg.
  2. Keurig K40 Open/Close Sensor Replacement: 步骤 2 中的图像 1,1
    • Unscrew both 1.5mm screws located on the water pump.
  3. Keurig K40 Open/Close Sensor Replacement: 步骤 3 中的图像 1,2 Keurig K40 Open/Close Sensor Replacement: 步骤 3 中的图像 2,2
    • Keeping one hand firmly placed on the device, tug upwards on the water pump until it is separated from the device.
    • The water pump and pipe should now be loose and easy to move as shown.
  4. Keurig K40 Open/Close Sensor Replacement: 步骤 4 中的图像 1,2 Keurig K40 Open/Close Sensor Replacement: 步骤 4 中的图像 2,2
    • Pull on the point where the pipe meets the water pump.
    • The pipe will come loose and the water filter will be free and ready to be replaced.
  5. Keurig K40 Open/Close Sensor Replacement, Open/Closed Sensor: 步骤 5 中的图像 1,2 Keurig K40 Open/Close Sensor Replacement, Open/Closed Sensor: 步骤 5 中的图像 2,2
    • Using a #2 Philips head screwdriver remove the 1.2mm screw holding the sensor in place.
    • Locate where the connections are soldered to the sensor
  6. Keurig K40 Open/Close Sensor Replacement: 步骤 6 中的图像 1,1
    • Melt the solder that is connected to the sensor.
    • Be careful to avoid any rubber and try to only contact the metal making the connection.
  7. Keurig K40 Open/Close Sensor Replacement: 步骤 7 中的图像 1,1
    • Put the replacement sensor back on the post that holds it and begin to solder the two metal connections back to the sensor.
    • Be careful not to touch the end of the soldering iron.
结论
另外一个人完成了本指南。
jonathan
于02/08/16注册
738 声望
创作了2篇指南
团队
USF Tampa, Team 6-1, Eyestone Spring 2016 USF Tampa, Team 6-1, Eyestone Spring 2016 的会员
USFT-EYESTONE-S16S6G1
3 名成员
创作了5篇指南
一条评论
Where can I get the open/closed sensor? I called Keurig and they told me they don’t handle them.
John Fictum - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 31
总计 3,756
