简介
Ok... I took photos AFTER I figured out how to disassemble. First, remove all the screws from the bottom of the Unit. Next, There are (6) screws on the BACK of the unit. These are covered by Screw Caps. Remove the Screw Caps then the screws. Next open up the front loader and remove the screws that hold the top cover. Then remove the Handle. After you remove the top and handle, you should be able to CAREFULLY pop off the front panel! From here the Sides and Top pop right off!! I'll try and get some photos as I reassemble. Thanks.
你所需要的
8等其他人完成本指南。
12条评论
My K155 doesn't let me Brew ,on the LCD screen it just say to lift the water reservoir and fill up, which I have done, I try the paper clip method , but since I can't brew the K155 does'nt allow me to try the declogging method. Please help
Tereza - 回复
I managed to remove the top cover for the cup holder and i see the front is fixed to the top and left with clips but i am unsure which side i need to pop first nor if im missing something. pictures of the dissassembly process woild be great.
edgarzaf - 回复
I don’t see any photos or instructions.
Jim Yanacek - 回复
we need pictures of disassembly and reassemble this keurig commercial k195 we need this to work is it strange but all these extremely large companies. i am !#^&@@ never helps you
jkp61648 - 回复
I sure wish you had a cheaper Keurig. I'm on social security and my sister lives by herself and really would love to have one. The cheapest one on market. Please, please, please. And can you please keep me notified
Kay Thatcher - 回复
