跳转到主内容
加入维修社区 - 创建账户
Keurig K10 Mini Plus Cup Holder Replacement
你所需要的
  1. Keurig K10 Mini Plus Cup Holder Replacement, Cup Holder: 步骤 1 中的图像 1,3 Keurig K10 Mini Plus Cup Holder Replacement, Cup Holder: 步骤 1 中的图像 2,3 Keurig K10 Mini Plus Cup Holder Replacement, Cup Holder: 步骤 1 中的图像 3,3
    • Press on tab while pulling up on K-cup until you hear a click. Repeat for the remaining tabs. We found using the smallest of the "plastic opening tools" worked wonders.
  2. Keurig K10 Mini Plus Cup Holder Replacement: 步骤 2 中的图像 1,2 Keurig K10 Mini Plus Cup Holder Replacement: 步骤 2 中的图像 2,2
    • Once all of the tabs have been pressed, the K-Cup should just pop out. After, you just pull the remainder of the K-Cup. You have successfully removed the K-Cup.
结论
Mark Henein
于02/04/16注册
369 声望
创作了2篇指南
团队
USF Tampa, Team 17-6, Blackwell Winter 2016 USF Tampa, Team 17-6, Blackwell Winter 2016 的会员
USFT-BLACKWELL-W16S17G6
2 名成员
创作了4篇指南
1指南评论
I accidentally removed the k cup holder while wiping it out. Now I have the holder plus 3 small plastic and 1 rubber circular pieces. How do I put it back together again? I have the same Kuerig mini as pictured here.
Marie - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 25
总计 1,668
