简介
This guide will help walk you through the steps of replacing the needle of a Keurig Mini. To get into the device all you will need is a #1 Philips screw driver.
你所需要的
Press on tab while pulling up on K-cup until you hear a click. Repeat for the remaining tabs. We found using the smallest of the "plastic opening tools" worked wonders.
Remove two 9 mm Phillips #1 screws.
The screws are located on the top of where the K-Cup would be.
2等其他人完成本指南。
1指南评论
Where do you buy the needle I know you can get the exit needle with the holder, but can’t find this one.
tbushwacker - 回复 分享
