跳转到主内容
Keurig B70 Platinum Water Filter Replacement
你所需要的
  1. Keurig B70 Platinum Water Filter Replacement, Water Filter: 步骤 1 中的图像 1,3 Keurig B70 Platinum Water Filter Replacement, Water Filter: 步骤 1 中的图像 2,3 Keurig B70 Platinum Water Filter Replacement, Water Filter: 步骤 1 中的图像 3,3
    • Remove the water reservoir from the Keurig by lifting it upwards and pulling it outwards.
    • Be sure to empty the reservoir before continuing to the next step.
  2. Keurig B70 Platinum Water Filter Replacement: 步骤 2 中的图像 1,3 Keurig B70 Platinum Water Filter Replacement: 步骤 2 中的图像 2,3 Keurig B70 Platinum Water Filter Replacement: 步骤 2 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Remove the three 11.0 mm screws from the reservoir filter.
    • You may need to use tweezers to pull out the screws.
  3. Keurig B70 Platinum Water Filter Replacement: 步骤 3 中的图像 1,3 Keurig B70 Platinum Water Filter Replacement: 步骤 3 中的图像 2,3 Keurig B70 Platinum Water Filter Replacement: 步骤 3 中的图像 3,3
    • Firmly twist the filter counterclockwise to remove it.
    • When adding the replacement filter, make sure the filter lines up with the screw holes.
结论
Emily Ramirez
于10/14/18注册
97 声望
撰写一个指南
团队
UW Tacoma, Team S1-G6, Rose Fall 2018 UW Tacoma, Team S1-G6, Rose Fall 2018 的会员
UWT-ROSE-F18S1G6
4 名成员
创作了5篇指南
4条评论
What are the two items inside the water resin?
There is the round item, and next to it an oblong item. I am really confused
Joan - 回复
The round item with 3 screws is the built in filter. The oblong item is the water level gauge.
Dacaria L -
I just ordered a filter starter kit. Do I just insert the kit on top of the round item?
Joan - 回复
I bought a Kuerig tall handle starter kit with charcoal filters. Tried install it over the existing built in filter, it didn’t fit. I think the round filter has to be removed in order to use the starter kit.
Dacaria L -
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 20
过去 30 天: 97
总计 10,512
