简介
If your puncture needle is damaged or dulled, follow this guide to safely remove and replace the puncture needle. The puncture needle is sharp so try to only touch the plastic holding the puncture needle. To complete the replacement, you will need a T15 Torx screwdriver, a Phillips #0 screwdriver, and a Phillips #2 screwdriver.
你所需要的
在这个步骤中使用的工具:Tweezers$4.99
Turn off and unplug the Keurig before starting.
Lay the Keurig on its back and open the lid.
Using a Phillips #2 screwdriver, remove the two 21.0 mm screws.
Using a Phillips #0 screwdriver, remove the two 7.0 mm screws located on the sides of the tube near the puncture needle.
