跳转到主内容
Keurig B70 Platinum K-Cup Portion Pack Holder Replacement
你所需要的
  1. Keurig B70 Platinum K-Cup Portion Pack Holder Replacement, K-Cup Portion Pack Holder: 步骤 1 中的图像 1,2 Keurig B70 Platinum K-Cup Portion Pack Holder Replacement, K-Cup Portion Pack Holder: 步骤 1 中的图像 2,2
    • Turn off and unplug the Keurig before starting.
    • Open the lid and remove the two 11.0 mm screws located below the K-Cup holder.
  2. Keurig B70 Platinum K-Cup Portion Pack Holder Replacement: 步骤 2 中的图像 1,1
    • Pull the black plastic guard of the K-Cup housing away from the Keurig.
    • Depending on the angle, the guard can actually fall out instead. Be ready to catch it!
  3. Keurig B70 Platinum K-Cup Portion Pack Holder Replacement: 步骤 3 中的图像 1,3 Keurig B70 Platinum K-Cup Portion Pack Holder Replacement: 步骤 3 中的图像 2,3 Keurig B70 Platinum K-Cup Portion Pack Holder Replacement: 步骤 3 中的图像 3,3
    • Push the black button at the bottom of the lid to remove the K-cup holder assembly.
    • From the top, lift the assembly out of the Keurig.
  4. Keurig B70 Platinum K-Cup Portion Pack Holder Replacement: 步骤 4 中的图像 1,2 Keurig B70 Platinum K-Cup Portion Pack Holder Replacement: 步骤 4 中的图像 2,2
    • Grab the top and the bottom of the holder assembly and pull it apart.
    • Be careful when pulling the assembly. There is a sharp needle!
    • This step requires a little force.
结论
Thu Hoang
于10/17/18注册
217 声望
创作了2篇指南
团队
UW Tacoma, Team S1-G6, Rose Fall 2018 UW Tacoma, Team S1-G6, Rose Fall 2018 的会员
UWT-ROSE-F18S1G6
4 名成员
创作了5篇指南
一条评论
Spring flew out as I was removing cup holder. Where does it go. How do I reinsert it?
slz2002 - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 31
总计 1,464
