跳转到主内容
Keurig B70 Platinum Base Replacement
你所需要的
  1. Keurig B70 Platinum Base Replacement, Base: 步骤 1 中的图像 1,2 Keurig B70 Platinum Base Replacement, Base: 步骤 1 中的图像 2,2
    • Turn off and unplug the Keurig before starting.
    • Turn the Keurig upside down so the metal base is exposed.
    • Remove the five 12.0 mm screws.
  2. Keurig B70 Platinum Base Replacement: 步骤 2 中的图像 1,2 Keurig B70 Platinum Base Replacement: 步骤 2 中的图像 2,2
    • Lift the metal plate off the Keurig and hang it over the side of the device.
    • Be careful! The metal plate is sharp!
    • There are wires connected to the metal plate. Make sure the wires are not in the way of the internal components.
  3. Keurig B70 Platinum Base Replacement: 步骤 3 中的图像 1,3 Keurig B70 Platinum Base Replacement: 步骤 3 中的图像 2,3 Keurig B70 Platinum Base Replacement: 步骤 3 中的图像 3,3
    • Remove the three 11.0 mm screws located on the upper left side of the base from within the tub-looking area.
    • Pull out the red and white wires and put it off to the side of the Keurig.
  4. Keurig B70 Platinum Base Replacement: 步骤 4 中的图像 1,3 Keurig B70 Platinum Base Replacement: 步骤 4 中的图像 2,3 Keurig B70 Platinum Base Replacement: 步骤 4 中的图像 3,3
    • Pull out the water collector by gripping it tightly and lifting upwards.
  5. Keurig B70 Platinum Base Replacement: 步骤 5 中的图像 1,3 Keurig B70 Platinum Base Replacement: 步骤 5 中的图像 2,3 Keurig B70 Platinum Base Replacement: 步骤 5 中的图像 3,3
    • Lift the tube, connected to the tank, off the black plastic hook and leave it off to the side of the hook.
  6. Keurig B70 Platinum Base Replacement: 步骤 6 中的图像 1,3 Keurig B70 Platinum Base Replacement: 步骤 6 中的图像 2,3 Keurig B70 Platinum Base Replacement: 步骤 6 中的图像 3,3
    • Pull the power cord out from the plastic holder located near the water tank.
    • This step requires a bit of force so don't be afraid to pull harder!
  7. Keurig B70 Platinum Base Replacement: 步骤 7 中的图像 1,2 Keurig B70 Platinum Base Replacement: 步骤 7 中的图像 2,2
    • Remove the six 13.0 mm screws.
  8. Keurig B70 Platinum Base Replacement: 步骤 8 中的图像 1,3 Keurig B70 Platinum Base Replacement: 步骤 8 中的图像 2,3 Keurig B70 Platinum Base Replacement: 步骤 8 中的图像 3,3
    • Lift the metal base and hover it over the opening of the black plastic base.
    • Carefully raise the plastic base over the metal base until it is removed.
    • Make sure to pull the power cord through the base as well!
结论
Steven Tran
于10/14/18注册
329 声望
创作了2篇指南
团队
UW Tacoma, Team S1-G6, Rose Fall 2018 UW Tacoma, Team S1-G6, Rose Fall 2018 的会员
UWT-ROSE-F18S1G6
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 19
总计 565
