跳转到主内容
Keurig 2.0-400 LCD Screen Replacement
你所需要的
  1. Keurig 2.0-400 LCD Screen Replacement, LCD Screen: 步骤 1 中的图像 1,1
    • Open the K-Cup Chamber Housing Lid by lifting up the silver handle below the LCD screen.
    • This is the part of the brewer you open to place a K-Cup inside.
  2. Keurig 2.0-400 LCD Screen Replacement: 步骤 2 中的图像 1,2 Keurig 2.0-400 LCD Screen Replacement: 步骤 2 中的图像 2,2
    • Place the Keurig on its side.
    • Remove the two 140mm screws located on the underside of the Chamber Lid using the Phillips #1 screwdriver.
    • Remove the top black housing that surrounds the screen.
  3. Keurig 2.0-400 LCD Screen Replacement: 步骤 3 中的图像 1,1
    • Using the Phillips #1 screwdriver, remove the two 140mm screws connecting the silver handle to the top of the Keurig.
  4. Keurig 2.0-400 LCD Screen Replacement: 步骤 4 中的图像 1,1
    • Pull out the front silver handle from the top of the brewer.
    • This will further expose the LCD screen.
  5. Keurig 2.0-400 LCD Screen Replacement: 步骤 5 中的图像 1,1
    • Using the metal spudger, pry open the snaps holding the LCD screen panel to the brewer, just enough for the panel to pop loose.
    • Warning: These snaps are very delicate and can easily be broken. Practice caution as you perform this step.
  6. Keurig 2.0-400 LCD Screen Replacement: 步骤 6 中的图像 1,1
    • Remove the top black housing by lifting it up.
    • This will expose the frame of the Keurig connecting to the LCD screen.
  7. Keurig 2.0-400 LCD Screen Replacement: 步骤 7 中的图像 1,1
    • Remove the black latch with the black wire connecting the front end of the panel to the frame.
    • The front end of the panel will now be free.
  8. Keurig 2.0-400 LCD Screen Replacement: 步骤 8 中的图像 1,1
    • On the bottom of the panel, remove the white tab that connects the wires of the circuit board to the LCD screen
    • To remove the tab, squeeze in on the sides of it as you pull it out.
    • Remove the touch screen panel from your device.
结论
5等其他人完成本指南。
Alec Jamosmos
于04/22/18注册
960 声望
创作了5篇指南
团队
Cal Poly, Team S24-G8, Maness Spring 2018 Cal Poly, Team S24-G8, Maness Spring 2018 的会员
CPSU-MANESS-S18S24G8
4 名成员
创作了10篇指南
4指南评论
Hello Alec,
Thank you for providing this repair guide! Could you kindly provide the screen size and where one might be able to purchase one? It would be greatly appreciated.
Regards.
Christopher Rodriguez - 回复
Yes love the demo, now where would one find the screen to replace. Keurig states these are no longer available.
staci werkmeister - 回复
Try eBay. I saw one there.
DEBORAH A YOCHIM - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 12
过去 30 天: 79
总计 17,567
