此翻译由机器生成,尚未经过人工审核。 会说这种语言吗? 查看评论。
简介
本指南将指导你更换微型泵。如果 Keurig 发生泄漏,或者液体无法正常排出,则需要执行此操作。
你所需要的
如图所示调整咖啡机的方向。
找到固定 Keurig 顶部中框的四颗 140 mm 螺丝。使用 Phillips 螺丝刀拆下这些螺丝。
其中两颗螺丝位于中框内侧,靠近热水器的地方。
另外两颗螺丝位于中框外侧。
要重新组装设备,请按相反顺序执行这些说明。
9等其他人完成本指南。
6指南评论
Why remove the circuit board?
Mel Jenkins - 回复 分享
Exactly my question ;)
Link to a new pump please
Spencer Long - 回复 分享
I agree. Why take out the circuit board. On the older Keurig models it was necessary to obtain access to the minipump, but for the 2.0 once the casing is completely removed access to the minipump is simple. However, if due to the failure of the minipump the pressure sensor ended up getting wet, then there might be a reason: to replace the sensor. There are videos claiming that 0V (0mV in this case) is the right output for the sensor. Not so, the correct output should be around 40mV when the pressure is zero. To test this, attach a voltmeter across pins 1 (-) & 3 (+) on the circuit board (pin 1 is above where the tube goes into the circuit board on the upper left side, 3 is upper right side, pins 4, 5, 6 on the bottom. Spec sheet for that device (FPN-07PG) is at https://www.fujikura.co.jp/eng/resource/.... With the tube disconnected, it will read ~.040 V. If it doesn't, try adding or subtracting pressure using a syringe--the voltage output should change.
Here is the spec sheet for the minipump: https://koge-europe.com/wp-content/uploa...
