跳转到主内容
Kenwood KDC-BT565U LCD Screen Replacement
你所需要的
  1. Kenwood KDC-BT565U LCD Screen Replacement, Face Plate: 步骤 1 中的图像 1,1
    • Press the eject button on the bottom left corner of the face plate.
  2. Kenwood KDC-BT565U LCD Screen Replacement: 步骤 2 中的图像 1,3 Kenwood KDC-BT565U LCD Screen Replacement: 步骤 2 中的图像 2,3 Kenwood KDC-BT565U LCD Screen Replacement: 步骤 2 中的图像 3,3
    • Begin by slightly lifting the face plate out from the side located by the release button.
    • Slide towards the side of the eject button, then completely lift out.
  3. Kenwood KDC-BT565U LCD Screen Replacement, LCD Screen: 步骤 3 中的图像 1,1
    • Remove the four 7.5mm Phillips #0 screws on the back of the face-plate.
  4. Kenwood KDC-BT565U LCD Screen Replacement: 步骤 4 中的图像 1,2 Kenwood KDC-BT565U LCD Screen Replacement: 步骤 4 中的图像 2,2
    • Use a spudger or prying tool to open the back of the face plate. Pry the back at multiple points around the edge of the face plate. This will take some patience. Applying too much force risks breaking the plastic.
  5. Kenwood KDC-BT565U LCD Screen Replacement: 步骤 5 中的图像 1,2 Kenwood KDC-BT565U LCD Screen Replacement: 步骤 5 中的图像 2,2
    • Lift and remove the motherboard to reveal the inside of the front panel.
    • You might need to pry the right side up with the spudger.
  6. Kenwood KDC-BT565U LCD Screen Replacement: 步骤 6 中的图像 1,3 Kenwood KDC-BT565U LCD Screen Replacement: 步骤 6 中的图像 2,3 Kenwood KDC-BT565U LCD Screen Replacement: 步骤 6 中的图像 3,3
    • Use the plastic spudger to straighten out the six pegs to allow the removal of the LCD screen.
    • Make sure to use an ESD-safe prying tool when working on electrical boards. Here, we are using a plastic tool, not a metal one.
  7. Kenwood KDC-BT565U LCD Screen Replacement: 步骤 7 中的图像 1,3 Kenwood KDC-BT565U LCD Screen Replacement: 步骤 7 中的图像 2,3 Kenwood KDC-BT565U LCD Screen Replacement: 步骤 7 中的图像 3,3
    • Lift the LCD screen to remove and replace it.
结论
3等其他人完成本指南。
Yusef Flowers
于02/15/17注册
137 声望
撰写一个指南
团队
USF Tampa, Team S2-G5, Lacy Spring 2017 USF Tampa, Team S2-G5, Lacy Spring 2017 的会员
USFT-LACY-S17S2G5
4 名成员
创作了11篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 445
