跳转到主内容
Kenwood KDC-BT565U Fuse Replacement
你所需要的
  1. Kenwood KDC-BT565U Fuse Replacement, Fuse: 步骤 1 中的图像 1,1
    • The fuse can be found on the back of your radio indicated by the red square in the photo.
  2. Kenwood KDC-BT565U Fuse Replacement: 步骤 2 中的图像 1,2 Kenwood KDC-BT565U Fuse Replacement: 步骤 2 中的图像 2,2
    • Pinch the fuse head with your fingers or a gripping tool to remove. This may require some force.
    • Reinsert a fuse that has the same amperage of the fuse that was previously removed (10 amps).
结论
To reassemble, follow these instructions in reverse order.
4等其他人完成本指南。
Darren Evans
于02/15/17注册
273 声望
创作了2篇指南
团队
USF Tampa, Team S2-G5, Lacy Spring 2017 USF Tampa, Team S2-G5, Lacy Spring 2017 的会员
USFT-LACY-S17S2G5
4 名成员
创作了11篇指南
7条评论
I disconnect the negative side on my 502 DPX Kenwood in-dash stereo system I replace the alternator and hook everything back up and now I have no power to the receiver
jasonfisher036@gmail.com - 回复
it does not explain how to pull the reciever out.
d_lalande - 回复
same problem, how to remove the receiver
Jason Armondo - 回复
I accidentally touch power on the radio casing now the radio will not turn on and the fuse is good I need help it’s a kenwood KDC-7011
Javier Castellanos - 回复
Did you ever find problem why your radio wouldn't turn on? Can you share with me. I have same problem
Jannie watkins -
添加评论
浏览统计数据:
过去 24 小时: 13
过去 7 天: 67
过去 30 天: 211
总计 21,415
