跳转到主内容
Kenwood DRV-N520 Dashcam Speaker Replacement
你所需要的
  1. Kenwood DRV-N520 Dashcam Speaker Replacement, Speaker: 步骤 1 中的图像 1,3 Kenwood DRV-N520 Dashcam Speaker Replacement, Speaker: 步骤 1 中的图像 2,3 Kenwood DRV-N520 Dashcam Speaker Replacement, Speaker: 步骤 1 中的图像 3,3
    • Use a Phillips #0 screwdriver to remove the four 3mm screws from the device backing.
    • Remove the backing.
  2. Kenwood DRV-N520 Dashcam Speaker Replacement: 步骤 2 中的图像 1,3 Kenwood DRV-N520 Dashcam Speaker Replacement: 步骤 2 中的图像 2,3 Kenwood DRV-N520 Dashcam Speaker Replacement: 步骤 2 中的图像 3,3
    • Use a Phillips #0 screwdriver to remove the four 3mm screws in the copper plate.
    • Remove the copper plate from the housing. The motherboard and capacitors should now be visible.
  3. Kenwood DRV-N520 Dashcam Speaker Replacement: 步骤 3 中的图像 1,2 Kenwood DRV-N520 Dashcam Speaker Replacement: 步骤 3 中的图像 2,2
    • Use the screwdriver to remove the two screws holding the motherboard in place.
    • Before attempting to remove the board, disconnect the camera by removing the ribbon cable from its corresponding connection on the board.
    • To remove the ribbon cable, use a plastic spudger to gently apply pressure to the lever that secures the cable in place while simultaneously applying a light pulling pressure on the ribbon cable.
    • Disconnect the speaker connections (red and black wires) from the motherboard by applying pressure to the clip on its corresponding socket.
    • Once all connections have been severed, gently remove the motherboard from the device casing.
    • The speaker unit and corresponding mounting hardware should now be visible.
  4. Kenwood DRV-N520 Dashcam Speaker Replacement: 步骤 4 中的图像 1,2 Kenwood DRV-N520 Dashcam Speaker Replacement: 步骤 4 中的图像 2,2
    • Use your Phillips #0 screwdriver to remove the two 3mm screws from the speaker's mounting bracket.
    • Remove the speaker from the device.
结论
To re-assemble your device, follow these steps in reverse order.
NathanGoodwin
于01/30/20注册
136 声望
撰写一个指南
团队
ERAU-LAMOTHE-S20S14G1 ERAU-LAMOTHE-S20S14G1 的会员
Repair Café
4 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 146
