跳转到主内容
Kenwood DNX571HD LCD Touch Screen Replacement
你所需要的
  1. Kenwood DNX571HD LCD Touch Screen Replacement, LCD Touch Screen: 步骤 1 中的图像 1,2 Kenwood DNX571HD LCD Touch Screen Replacement, LCD Touch Screen: 步骤 1 中的图像 2,2
    • Turn off the stereo and remove from the vehicle before starting.
    • Unscrew the four 3.5mm side screws with a Phillips #1 screwdriver.
    • There are two screws per side.
  2. Kenwood DNX571HD LCD Touch Screen Replacement: 步骤 2 中的图像 1,3 Kenwood DNX571HD LCD Touch Screen Replacement: 步骤 2 中的图像 2,3 Kenwood DNX571HD LCD Touch Screen Replacement: 步骤 2 中的图像 3,3
    • Use a spudger to unhook the plastic clips on the sides and top of the front panel. There are two clips on each side and one clip on the top.
    • Place the spudger between the plastic tab and the metal case and gently lift the spudger away from the case.
  3. Kenwood DNX571HD LCD Touch Screen Replacement: 步骤 3 中的图像 1,1
    • Pull the top of the front panel out and down to remove front panel.
    • Remove the front panel gently so as not to damage the ribbon cables behind it.
  4. Kenwood DNX571HD LCD Touch Screen Replacement: 步骤 4 中的图像 1,2 Kenwood DNX571HD LCD Touch Screen Replacement: 步骤 4 中的图像 2,2
    • Flip up the black clasp with the spudger to disconnect the small white ribbon cable from the main board.
  5. Kenwood DNX571HD LCD Touch Screen Replacement: 步骤 5 中的图像 1,2 Kenwood DNX571HD LCD Touch Screen Replacement: 步骤 5 中的图像 2,2
    • Flip up the black clasp with the spudger to disconnect the large white ribbon cable from the main board.
  6. Kenwood DNX571HD LCD Touch Screen Replacement: 步骤 6 中的图像 1,2 Kenwood DNX571HD LCD Touch Screen Replacement: 步骤 6 中的图像 2,2
    • Flip up the black clasp with the spudger to disconnect the small white ribbon cable from the vertical board.
    • Carefully pull the ribbon from the clasp with the spudger.
  7. Kenwood DNX571HD LCD Touch Screen Replacement: 步骤 7 中的图像 1,2 Kenwood DNX571HD LCD Touch Screen Replacement: 步骤 7 中的图像 2,2
    • Flip up the black clasp with the spudger to disconnect the large orange ribbon cable from the main board.
  8. Kenwood DNX571HD LCD Touch Screen Replacement: 步骤 8 中的图像 1,2 Kenwood DNX571HD LCD Touch Screen Replacement: 步骤 8 中的图像 2,2
    • Push out the black clasp with the spudger to disconnect the small orange ribbon cable from the main board.
    • Gently push the ribbon out of the clasp with the spudger.
  9. Kenwood DNX571HD LCD Touch Screen Replacement: 步骤 9 中的图像 1,2 Kenwood DNX571HD LCD Touch Screen Replacement: 步骤 9 中的图像 2,2
    在这个步骤中使用的工具:
    • Using a pair of tweezers, gently pull up on the connector for the power cable to disconnect it from the main board.
  10. Kenwood DNX571HD LCD Touch Screen Replacement: 步骤 10 中的图像 1,2 Kenwood DNX571HD LCD Touch Screen Replacement: 步骤 10 中的图像 2,2
    • Unscrew the two 4mm screws holding down the board that is standing vertically with a Phillips #1 screwdriver.
    • Pull up on the board to remove it.
  11. Kenwood DNX571HD LCD Touch Screen Replacement: 步骤 11 中的图像 1,2 Kenwood DNX571HD LCD Touch Screen Replacement: 步骤 11 中的图像 2,2
    • Unscrew the four 5.5mm screws with a JIS #00 screwdriver.
    • Unscrew the 4mm screw with a Phillips #1 screwdriver.
    • Remove the disconnected circuit board.
  12. Kenwood DNX571HD LCD Touch Screen Replacement: 步骤 12 中的图像 1,2 Kenwood DNX571HD LCD Touch Screen Replacement: 步骤 12 中的图像 2,2
    • Unscrew the four 4mm screws on the main board with a Phillips #1 screwdriver.
    • Gently lift the board out of the casing.
    • Unscrew the 5.5mm screw on the metal plate with a JIS #00 screwdriver.
  13. Kenwood DNX571HD LCD Touch Screen Replacement: 步骤 13 中的图像 1,1
    • Carefully remove the tape attaching the power cable to the metal plate.
  14. Kenwood DNX571HD LCD Touch Screen Replacement: 步骤 14 中的图像 1,2 Kenwood DNX571HD LCD Touch Screen Replacement: 步骤 14 中的图像 2,2
    • Use the spudger to unhook the metal tabs and detach the metal plate from the plastic housing.
    • Place the spudger between the metal tab and the plastic case and gently lift the spudger away from the case.
  15. Kenwood DNX571HD LCD Touch Screen Replacement: 步骤 15 中的图像 1,2 Kenwood DNX571HD LCD Touch Screen Replacement: 步骤 15 中的图像 2,2
    • Gently press the front of the screen to detach it from the plastic housing.
    • When removing the screen, gently flex out the plastic housing to help get the display past the plastic latch.
结论
5等其他人完成本指南。
Wendy Zaballos
于09/17/18注册
976 声望
创作了6篇指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 23
过去 30 天: 83
总计 10,746
