跳转到主内容
Kenwood DNX571HD Cooling Fan Replacement
你所需要的
  1. Kenwood DNX571HD Cooling Fan Replacement, CD/DVD Drive: 步骤 1 中的图像 1,2 Kenwood DNX571HD Cooling Fan Replacement, CD/DVD Drive: 步骤 1 中的图像 2,2
    • Unscrew the four 3.5mm side screws with a Phillips #1 screwdriver.
    • There are two screws per side.
  2. Kenwood DNX571HD Cooling Fan Replacement: 步骤 2 中的图像 1,3 Kenwood DNX571HD Cooling Fan Replacement: 步骤 2 中的图像 2,3 Kenwood DNX571HD Cooling Fan Replacement: 步骤 2 中的图像 3,3
    • Use a spudger to unhook the plastic clips on the sides and top of the front panel. There are two clips on each side and one clip on the top.
    • Place the spudger between the plastic tab and the metal case and gently lift the spudger away from the case.
  3. Kenwood DNX571HD Cooling Fan Replacement: 步骤 3 中的图像 1,1
    • Pull the top of the front panel out and down to remove front panel.
    • Remove the front panel gently so as not to damage the ribbon cables behind it.
  4. Kenwood DNX571HD Cooling Fan Replacement: 步骤 4 中的图像 1,3 Kenwood DNX571HD Cooling Fan Replacement: 步骤 4 中的图像 2,3 Kenwood DNX571HD Cooling Fan Replacement: 步骤 4 中的图像 3,3
    • Unscrew the three 5mm screws from the top of the device using a Phillips #1 screwdriver.
    • Lift up to remove the top casing.
  5. Kenwood DNX571HD Cooling Fan Replacement: 步骤 5 中的图像 1,1
    • Lift the CD drive carefully to expose the attached cable underneath.
  6. Kenwood DNX571HD Cooling Fan Replacement: 步骤 6 中的图像 1,2 Kenwood DNX571HD Cooling Fan Replacement: 步骤 6 中的图像 2,2
    • Flip up the black clasp with a spudger to disconnect the large white ribbon cable connecting the CD drive to the board underneath.
  7. Kenwood DNX571HD Cooling Fan Replacement, Cooling Fan: 步骤 7 中的图像 1,1
    • Carefully unplug the fan power cord with the tweezers.
  8. Kenwood DNX571HD Cooling Fan Replacement: 步骤 8 中的图像 1,2 Kenwood DNX571HD Cooling Fan Replacement: 步骤 8 中的图像 2,2
    • Unscrew the three 5mm length screws with the Phillips #1 screwdriver.
    • Remove the metal plate
    • Removing the plate will damage the heat sink compound. This will need to be replaced during reassembly.
  9. Kenwood DNX571HD Cooling Fan Replacement: 步骤 9 中的图像 1,2 Kenwood DNX571HD Cooling Fan Replacement: 步骤 9 中的图像 2,2
    • Unscrew the three 5.5mm long screws with a Phillips #1 screwdriver.
  10. Kenwood DNX571HD Cooling Fan Replacement: 步骤 10 中的图像 1,3 Kenwood DNX571HD Cooling Fan Replacement: 步骤 10 中的图像 2,3 Kenwood DNX571HD Cooling Fan Replacement: 步骤 10 中的图像 3,3
    • Remove the four 5.5mm screws with the Phillips #1 screwdriver.
  11. Kenwood DNX571HD Cooling Fan Replacement: 步骤 11 中的图像 1,1
    • Lift the top part of the unit up from the lower chassis.
  12. Kenwood DNX571HD Cooling Fan Replacement: 步骤 12 中的图像 1,2 Kenwood DNX571HD Cooling Fan Replacement: 步骤 12 中的图像 2,2
    • Remove the two 13mm long screws with a Phillips #1 screwdriver.
    • Gently thread the power cable through the circuit boards to separate the fan from the body of the stereo.
结论
Wendy Zaballos
于09/17/18注册
952 声望
创作了6篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 896
