跳转到主内容
Kenwood Chef A701A Power Cable Replacement
你所需要的
  1. Kenwood Chef A701A Power Cable Replacement, Remove Cable Grips: 步骤 1 中的图像 1,2 Kenwood Chef A701A Power Cable Replacement, Remove Cable Grips: 步骤 1 中的图像 2,2
    • Turn the mixer upside down
    • Remove the two screws holding the white cable grip.
    • Remove the black cable grip. The long screw also holds the cover onto the terminal block
  2. Kenwood Chef A701A Power Cable Replacement, Remove the old cable: 步骤 2 中的图像 1,1
    • Remove the cable cover to expose the terminal block.
    • Remove the wires from the live and neutral terminals.
    • Thread the cables out though the cover and then from the mixer chassis
    • To refit simply follow the removal process in reverse
    • Be sure to connect the wires to the correct terminals, Brown - Live, Blue, Neutral.
    • If fitting a new plug ensure it is fitted with the appropriate fuse. If in any doubt consult a compitent electrician/electrical engineer
结论
4等其他人完成本指南。
Grant
于09/29/15注册
143 声望
撰写一个指南
一条评论
Important addition: make sure you leave enough cable length free under the mixer for when you raise the top of the mixer during use to change accessories or remove the bowl. Our local electrical repair shop didn’t think to do this and as soon as I raised the top the cable was pulled out.
Karen Leach - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 13
过去 30 天: 61
总计 9,364
