当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Starting with the left speaker first, pull out one side of the speaker clamp where the clamp enters the hole on the speaker cover.
Do not pull out the speaker clamp with too much force, or it may break.
After one side of the speaker clamp is removed from the speaker cover, pull the other side of the speaker clamp out.
Hold the speaker cover in one hand and the speaker ear-padding in the other.
Turn the speaker cover counter-clockwise until it stops turning.
Pull the speaker cover and the speaker ear padding apart to expose the inner components of the speaker.
Make sure to pull the speakers apart gently to avoid disconnecting the speaker cable wires from the speaker.
If the speaker cover and ear-padding don't easily come apart, then make sure the speaker cover is fully turned.
Repeat this process for both speakers.
With the internal speaker component exposed, the wires connecting the speakers to the speaker cable can be cut.
Reassembly after cutting the speaker cable wires will require soldering. Proceed with caution. See Kensington Hi-Fi Headphones 33137 Speaker Cable Replacement.
Cut each of the wires connecting the speaker to the speaker cable.
Repeat this process for each speaker.
After cutting the wires, untie the knot that is in the speaker cable.
Repeat this process for each side of the speaker cable.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
