跳转到主内容
Kensington Hi-Fi Headphones 33137 Headband
你所需要的
  1. Kensington Hi-Fi Headphones 33137 Headband, Inner Headband Cover: 步骤 1 中的图像 1,3 Kensington Hi-Fi Headphones 33137 Headband, Inner Headband Cover: 步骤 1 中的图像 2,3 Kensington Hi-Fi Headphones 33137 Headband, Inner Headband Cover: 步骤 1 中的图像 3,3
    • Starting with the left speaker first, pull out one side of the speaker clamp where the clamp enters the hole on the speaker cover.
    • Do not pull out the speaker clamp with too much force, or it may break.
    • After one side of the speaker clamp is removed from the speaker cover, pull the other side of the speaker clamp out.
  2. Kensington Hi-Fi Headphones 33137 Headband: 步骤 2 中的图像 1,3 Kensington Hi-Fi Headphones 33137 Headband: 步骤 2 中的图像 2,3 Kensington Hi-Fi Headphones 33137 Headband: 步骤 2 中的图像 3,3
    • Repeat the process in Step 1 to remove the right speaker clamp.
  3. Kensington Hi-Fi Headphones 33137 Headband: 步骤 3 中的图像 1,2 Kensington Hi-Fi Headphones 33137 Headband: 步骤 3 中的图像 2,2
    • This picture shows the headphones with the speakers detached. Steps 1 and 2 are not necessary to replace the headband covers, however they do make the process easier.
    • Turn the headphones so that the inner headphone cover is visible.
  4. Kensington Hi-Fi Headphones 33137 Headband: 步骤 4 中的图像 1,2 Kensington Hi-Fi Headphones 33137 Headband: 步骤 4 中的图像 2,2
    • Use the Phillips #00 screwdriver to loosen and remove the screw holding the inner headphone cover in place.
    • The screw dimensions are as follows: Length to Head = 4 mm, Head Length = 1.5 mm, Head Diameter = 3.5 mm, Major Diameter = 2 mm, Pitch = 0.5 mm.
    • All steps can be followed on both the left or right side of the headphones to remove inner coverings.
  5. Kensington Hi-Fi Headphones 33137 Headband: 步骤 5 中的图像 1,3 Kensington Hi-Fi Headphones 33137 Headband: 步骤 5 中的图像 2,3 Kensington Hi-Fi Headphones 33137 Headband: 步骤 5 中的图像 3,3
    • Use the screwdriver to pry the inner headband covering loose.
    • Do not push the inner covering panel too hard, or the plastic will break. Only apply enough pressure to lift the panel up slightly.
    • Once the inner covering is loose, pull it free from the headband with your fingers and set it aside.
    • Make sure to pull the inner cover free gently do avoid losing the adjustment piece within the cover. It falls out easily and can be lost.
  6. Kensington Hi-Fi Headphones 33137 Headband, Speaker Clamp: 步骤 6 中的图像 1,3 Kensington Hi-Fi Headphones 33137 Headband, Speaker Clamp: 步骤 6 中的图像 2,3 Kensington Hi-Fi Headphones 33137 Headband, Speaker Clamp: 步骤 6 中的图像 3,3
    • Turn the headphones so that the inner tab of the speaker clamp where it attaches to the headband can be seen.
    • Pull the speaker clamp so that the metal lifts free of the headband.
  7. Kensington Hi-Fi Headphones 33137 Headband: 步骤 7 中的图像 1,1
    • Remove the speaker clamp.
    • All steps can be followed on either the left or right arm of the headphones to remove speaker clamps.
  8. Kensington Hi-Fi Headphones 33137 Headband, Headband Adjustment Piece: 步骤 8 中的图像 1,2 Kensington Hi-Fi Headphones 33137 Headband, Headband Adjustment Piece: 步骤 8 中的图像 2,2
    • Turn the headphones so that the metal pieces inside the headband covering can be seen.
  9. Kensington Hi-Fi Headphones 33137 Headband: 步骤 9 中的图像 1,2 Kensington Hi-Fi Headphones 33137 Headband: 步骤 9 中的图像 2,2
    • With your fingers, lift the small metal headband adjustment piece.
    • Remove the piece and set it aside.
    • All steps can be followed on either the left or right arm of the headphones to remove adjustment pieces.
  10. Kensington Hi-Fi Headphones 33137 Headband, Headband: 步骤 10 中的图像 1,2 Kensington Hi-Fi Headphones 33137 Headband, Headband: 步骤 10 中的图像 2,2
    • Turn the headphones so that the metal part of the headband located inside the outer covering can be seen.
  11. Kensington Hi-Fi Headphones 33137 Headband: 步骤 11 中的图像 1,3 Kensington Hi-Fi Headphones 33137 Headband: 步骤 11 中的图像 2,3 Kensington Hi-Fi Headphones 33137 Headband: 步骤 11 中的图像 3,3
    • With your fingers, pull the metal arm of the headband free of the plastic outer covering.
    • Set the outer covering aside.
  12. Kensington Hi-Fi Headphones 33137 Headband: 步骤 12 中的图像 1,1
    • All steps must be followed on both the left and right arms of the headband to free it completely from the outer coverings.
结论
Alexis Carr
于03/26/14注册
417 声望
创作了4篇指南
团队
Clemson, Team 1-3, Benson Spring 2014 Clemson, Team 1-3, Benson Spring 2014 的会员
CLEM-BENSON-S14S1G3
3 名成员
创作了18篇指南
一条评论
Do you know how to make an adjustable headband for custom headphones? Please contact me!
Lisa Campbell
Owner Lit Headphones L.L.C.
LitHeadphones.com
MsLisaShawnitaCampbell@gmail.com
Lisa Campbell - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 536
