当前版本的文档还未经巡查,您可以查看最新的已查核版本 。
Starting with the left speaker first, pull out one side of the speaker clamp where the clamp enters the hole on the speaker cover.
Do not pull out the speaker clamp with too much force, or it may break.
After one side of the speaker clamp is removed from the speaker cover, pull the other side of the speaker clamp out.
This picture shows the headphones with the speakers detached. Steps 1 and 2 are not necessary to replace the headband covers, however they do make the process easier.
Turn the headphones so that the inner headphone cover is visible.
Use the Phillips #00 screwdriver to loosen and remove the screw holding the inner headphone cover in place.
The screw dimensions are as follows: Length to Head = 4 mm, Head Length = 1.5 mm, Head Diameter = 3.5 mm, Major Diameter = 2 mm, Pitch = 0.5 mm.
All steps can be followed on both the left or right side of the headphones to remove inner coverings.
Use the screwdriver to pry the inner headband covering loose.
Do not push the inner covering panel too hard, or the plastic will break. Only apply enough pressure to lift the panel up slightly.
Once the inner covering is loose, pull it free from the headband with your fingers and set it aside.
Make sure to pull the inner cover free gently do avoid losing the adjustment piece within the cover. It falls out easily and can be lost.
With your fingers, lift the small metal headband adjustment piece.
Remove the piece and set it aside.
All steps can be followed on either the left or right arm of the headphones to remove adjustment pieces.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
单个步骤
完整指南
小——600像素
中——800像素
大——1200像素
预览
