跳转到主内容
Kenmore 90 Series Washing Machine Drive Motor Coupling Replacement
你所需要的
  1. Kenmore 90 Series Washing Machine Drive Motor Coupling Replacement, Drive Motor Coupling: 步骤 1 中的图像 1,3 Kenmore 90 Series Washing Machine Drive Motor Coupling Replacement, Drive Motor Coupling: 步骤 1 中的图像 2,3 Kenmore 90 Series Washing Machine Drive Motor Coupling Replacement, Drive Motor Coupling: 步骤 1 中的图像 3,3
    • Unplug the washing machine.
    • Using a flat head screwdriver, gently wedge the end caps off of the control console in order to open it up.
  2. Kenmore 90 Series Washing Machine Drive Motor Coupling Replacement: 步骤 2 中的图像 1,3 Kenmore 90 Series Washing Machine Drive Motor Coupling Replacement: 步骤 2 中的图像 2,3 Kenmore 90 Series Washing Machine Drive Motor Coupling Replacement: 步骤 2 中的图像 3,3
    • Lift and swing the console upward.
  3. Kenmore 90 Series Washing Machine Drive Motor Coupling Replacement: 步骤 3 中的图像 1,3 Kenmore 90 Series Washing Machine Drive Motor Coupling Replacement: 步骤 3 中的图像 2,3 Kenmore 90 Series Washing Machine Drive Motor Coupling Replacement: 步骤 3 中的图像 3,3
    • Unplug the lid-switch secured under the console.
  4. Kenmore 90 Series Washing Machine Drive Motor Coupling Replacement: 步骤 4 中的图像 1,3 Kenmore 90 Series Washing Machine Drive Motor Coupling Replacement: 步骤 4 中的图像 2,3 Kenmore 90 Series Washing Machine Drive Motor Coupling Replacement: 步骤 4 中的图像 3,3
    • Remove the console clips using a flat head screwdriver to release the chassis.
  5. Kenmore 90 Series Washing Machine Drive Motor Coupling Replacement: 步骤 5 中的图像 1,3 Kenmore 90 Series Washing Machine Drive Motor Coupling Replacement: 步骤 5 中的图像 2,3 Kenmore 90 Series Washing Machine Drive Motor Coupling Replacement: 步骤 5 中的图像 3,3
    • Stand in front of the washer and remove the chassis by lifting and pulling it towards you to expose the lower components.
  6. Kenmore 90 Series Washing Machine Drive Motor Coupling Replacement: 步骤 6 中的图像 1,2 Kenmore 90 Series Washing Machine Drive Motor Coupling Replacement: 步骤 6 中的图像 2,2
    • Use the flat head screwdriver to flip the restraining clips and release the drain pump.
  7. Kenmore 90 Series Washing Machine Drive Motor Coupling Replacement: 步骤 7 中的图像 1,2 Kenmore 90 Series Washing Machine Drive Motor Coupling Replacement: 步骤 7 中的图像 2,2
    • Remove the drive motor by unplugging the motor connector.
  8. Kenmore 90 Series Washing Machine Drive Motor Coupling Replacement: 步骤 8 中的图像 1,2 Kenmore 90 Series Washing Machine Drive Motor Coupling Replacement: 步骤 8 中的图像 2,2
    • Remove connections to the capacitor.
  9. Kenmore 90 Series Washing Machine Drive Motor Coupling Replacement: 步骤 9 中的图像 1,3 Kenmore 90 Series Washing Machine Drive Motor Coupling Replacement: 步骤 9 中的图像 2,3 Kenmore 90 Series Washing Machine Drive Motor Coupling Replacement: 步骤 9 中的图像 3,3
    • Place the drive motor to the side and remove the direct drive coupler by sliding it off.
  10. Kenmore 90 Series Washing Machine Drive Motor Coupling Replacement: 步骤 10 中的图像 1,2 Kenmore 90 Series Washing Machine Drive Motor Coupling Replacement: 步骤 10 中的图像 2,2
    • Replace with the new direct drive coupler and use the end of your screwdriver to seat it flush on the drive motor.
结论
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 26
过去 30 天: 113
总计 5,182
