跳转到主内容
Kenmore 80 Series Washing Machine Lid Switch Replacement
你所需要的
  1. Kenmore 80 Series Washing Machine Lid Switch Replacement, open console: 步骤 1 中的图像 1,2 Kenmore 80 Series Washing Machine Lid Switch Replacement, open console: 步骤 1 中的图像 2,2
    • Control panel console is fastened with two screws. Remove screws, pull bottom end of control panel forward (towards you), swing it upward, rest it in flipped position.
  2. Kenmore 80 Series Washing Machine Lid Switch Replacement, unplug switch: 步骤 2 中的图像 1,2 Kenmore 80 Series Washing Machine Lid Switch Replacement, unplug switch: 步骤 2 中的图像 2,2
    • Press on tab to release clip/latch. Grip connector, not wires, and pull it off of fixed connector.
  3. Kenmore 80 Series Washing Machine Lid Switch Replacement, open case: 步骤 3 中的图像 1,3 Kenmore 80 Series Washing Machine Lid Switch Replacement, open case: 步骤 3 中的图像 2,3 Kenmore 80 Series Washing Machine Lid Switch Replacement, open case: 步骤 3 中的图像 3,3
    • Use prise tool to remove two case clips. Pull top of case towards you, rock case (almost whole cabinet: case top, front, left & right) on its bottom front edge as axis, lower front of case until it rests on floor.
  4. Kenmore 80 Series Washing Machine Lid Switch Replacement, remove wiring: 步骤 4 中的图像 1,3 Kenmore 80 Series Washing Machine Lid Switch Replacement, remove wiring: 步骤 4 中的图像 2,3 Kenmore 80 Series Washing Machine Lid Switch Replacement, remove wiring: 步骤 4 中的图像 3,3
    • Case grounding wire is fastened on with one screw, 5/16 (five sixteenths) inch hexagon head. Unhook wires from the guide hooks.
  5. Kenmore 80 Series Washing Machine Lid Switch Replacement, remove switch: 步骤 5 中的图像 1,2 Kenmore 80 Series Washing Machine Lid Switch Replacement, remove switch: 步骤 5 中的图像 2,2
    • Switch is fastened on with two screws.
    • Remove connector from case top, squeezing connector's panel mount tabs to free it. when replacing: Face connector with its wedge bump facing frontward.
结论
2等其他人完成本指南。
unsubstantiated
于06/07/16注册
1,066 声望
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 51
过去 30 天: 173
总计 9,074
