跳转到主内容
Kenmore 78423 Dustbin filter Replacement
  1. Kenmore 78423 Dustbin filter Replacement, Dust Bin: 步骤 1 中的图像 1,2 Kenmore 78423 Dustbin filter Replacement, Dust Bin: 步骤 1 中的图像 2,2
    • Grab the dustbin handle, press and hold the button at the top of the handle.
    • Pull the dustbin up and away from the main body.
  2. Kenmore 78423 Dustbin filter Replacement: 步骤 2 中的图像 1,2 Kenmore 78423 Dustbin filter Replacement: 步骤 2 中的图像 2,2
    • Press the button located beneath the circular opening on the dust bin; this will open the bottom of the dustbin.
    • Properly dispose any contents of the dust bin into a wastebasket.
  3. Kenmore 78423 Dustbin filter Replacement, Dustbin Filters: 步骤 3 中的图像 1,3 Kenmore 78423 Dustbin filter Replacement, Dustbin Filters: 步骤 3 中的图像 2,3 Kenmore 78423 Dustbin filter Replacement, Dustbin Filters: 步骤 3 中的图像 3,3
    • Pinch and grasp the raised handle on the primary dustbin filter.
    • Lift the primary dustbin filter up and away from the dustbin and place it to the side.
  4. Kenmore 78423 Dustbin filter Replacement: 步骤 4 中的图像 1,2 Kenmore 78423 Dustbin filter Replacement: 步骤 4 中的图像 2,2
    • Grasp the foam filter and lift up to remove.
    • The foam filter may be lodged inside of the primary dustbin filter. In this case, both filters may be removed at the same time.
结论
另外一个人完成了本指南。
团队
CSU Fullerton, Team S2-G4, Bruce Fall 2018 CSU Fullerton, Team S2-G4, Bruce Fall 2018 的会员
CSUF-BRUCE-F18S2G4
4 名成员
创作了10篇指南
2条评论
What is the part number so I can purchase and replace dustbin filter
Bob Roper - 回复
Kenmore 78423 Dustbin Filters, where can I purchase new ones?
Bob Roper - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 26
总计 904
