跳转到主内容
Kenmore 110 Series Washing Machine Water Pump Replacement
你所需要的
  1. Kenmore 110 Series Washing Machine Water Pump Replacement, Water Pump: 步骤 1 中的图像 1,1
    • Unplug the washing machine!
    • Carefully lay washing machine on its back.
  2. Kenmore 110 Series Washing Machine Water Pump Replacement: 步骤 2 中的图像 1,3 Kenmore 110 Series Washing Machine Water Pump Replacement: 步骤 2 中的图像 2,3 Kenmore 110 Series Washing Machine Water Pump Replacement: 步骤 2 中的图像 3,3
    • Carefully remove both wire harnesses connected to the pump.
    • Squeeze and pull back hose clamp.
    • Twist drain hose off of pump.
    • Using a 1/4" socket wrench, remove the three mounting screws.
    • Pull the pump out of place.
    • Pulling the pump away takes a little force.
结论
14等其他人完成本指南。
Robert Trout
于09/26/12注册
1,234 声望
创作了5篇指南
团队
Cal Poly, Team 15-43, Forte Fall 2012 Cal Poly, Team 15-43, Forte Fall 2012 的会员
CPSU-FORTE-F12S15G43
5 名成员
创作了11篇指南
9条评论
please provide info on how to test the water pump once it's removed...
Oscar Ramos - 回复
The instructions say nothing of the pulley belt and wheel.
I'm looking to work on a 110. 81080100
and
I have read that transmission fluid leaks out when the washer is on its side.
Is there a way to temporarily plug it?
thomas - 回复
My clothes are still really wet.
Tracy Schultz - 回复
Washer doesn't move doesn't do any thing it just hummus won't drain water
Hector Rios - 回复
添加评论
浏览统计数据:
过去 24 小时: 14
过去 7 天: 87
过去 30 天: 340
总计 58,686
