跳转到主内容
Kenmore 110 Series Washing Machine Water Level Sensor Replacement
你所需要的
  1. Kenmore 110 Series Washing Machine Water Level Sensor Replacement, Water Level Sensor: 步骤 1 中的图像 1,1
    • Unplug the washing machine!
    • Using a 5/16" socket wrench or an adjustable wrench, remove the three screws from the top rear of the washer.
    • Lifting from the rear, remove the top panel.
    • The top panel will still be connected by wires and hoses. It will help if you have a flat raised surface to set the top panel on.
  2. Kenmore 110 Series Washing Machine Water Level Sensor Replacement: 步骤 2 中的图像 1,3 Kenmore 110 Series Washing Machine Water Level Sensor Replacement: 步骤 2 中的图像 2,3 Kenmore 110 Series Washing Machine Water Level Sensor Replacement: 步骤 2 中的图像 3,3
    • Using a 5/16" socket wrench or a hand wrench, remove the two screws from the component cover.
    • From the bottom, pull out and remove the component cover.
  3. Kenmore 110 Series Washing Machine Water Level Sensor Replacement: 步骤 3 中的图像 1,3 Kenmore 110 Series Washing Machine Water Level Sensor Replacement: 步骤 3 中的图像 2,3 Kenmore 110 Series Washing Machine Water Level Sensor Replacement: 步骤 3 中的图像 3,3
    • Remove wires from water level sensor.
    • With a Phillips screwdriver remove the mounting screw.
    • Cut the zip tie and remove water level hose.
结论
5等其他人完成本指南。
Robert Trout
于09/26/12注册
1,234 声望
创作了5篇指南
团队
Cal Poly, Team 15-43, Forte Fall 2012 Cal Poly, Team 15-43, Forte Fall 2012 的会员
CPSU-FORTE-F12S15G43
5 名成员
创作了12篇指南
4条评论
how to test water level switch??
countryrhoads4x4 - 回复
What is the water sensor part # for a Kenmore model #11029842990?
Who has that part 4the best price?
Rod Brannon - 回复
Hi,
I replaced the water-level pressure switch with a new kit but it did not resolve my problem. After installing the switch and line, I selected the lowest level but the tub continued to fill beyond the smallest wash level. I have a Kenmore Model # 110.20902. What other part or solution could resolve my issue?
BTW: I read replacing the water inlet valve night be involved but I already did that within the last six months and everything worked fine until I noticed the water level had changed the last two washes to a large load only. In fact, the water looked above the large level during my last wash.
I would appreciate any insight.
Shannon
Shannon - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 30
过去 30 天: 160
总计 41,453
