跳转到主内容
Kenmore 110 Series Washing Machine Electronic Control Replacement
你所需要的
  1. Kenmore 110 Series Washing Machine Electronic Control Replacement, Electronic Control: 步骤 1 中的图像 1,1
    • Unplug the washing machine!
    • Using a 5/16" socket wrench or an adjustable wrench, remove the three screws from the top rear of the washer.
    • Lifting from the rear, remove the top panel.
    • The top panel will still be connected by wires and hoses. It will help if you have a flat raised surface to set the top panel on.
  2. Kenmore 110 Series Washing Machine Electronic Control Replacement: 步骤 2 中的图像 1,3 Kenmore 110 Series Washing Machine Electronic Control Replacement: 步骤 2 中的图像 2,3 Kenmore 110 Series Washing Machine Electronic Control Replacement: 步骤 2 中的图像 3,3
    • Using a 5/16" socket wrench or a hand wrench, remove the two screws from the component cover.
    • From the bottom, pull out and remove the component cover.
  3. Kenmore 110 Series Washing Machine Electronic Control Replacement: 步骤 3 中的图像 1,2 Kenmore 110 Series Washing Machine Electronic Control Replacement: 步骤 3 中的图像 2,2
    • Carefully remove the three wire harnesses.
    • With a phillips head screwdriver, remove the three mounting screws.
结论
10等其他人完成本指南。
Robert Trout
于09/26/12注册
1,234 声望
创作了5篇指南
团队
Cal Poly, Team 15-43, Forte Fall 2012 Cal Poly, Team 15-43, Forte Fall 2012 的会员
CPSU-FORTE-F12S15G43
5 名成员
创作了11篇指南
3条评论
the machine is not completing the wash cycle. stop in the rinse and spin cycle.
is there a fix for this?
R Snagg - 回复
I am having the same problem. Did you ever find a fix?
Paul Bennett -
Did anyone find a fix for this problem?
Ron Rafe - 回复
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 37
过去 30 天: 154
总计 27,618
