跳转到主内容
Kenmore 110 Series Washing Machine Drive Belt Replacement
你所需要的
  1. Kenmore 110 Series Washing Machine Drive Belt Replacement, Drive Belt: 步骤 1 中的图像 1,1
    • To avoid risk of electric shock, unplug the washing machine.
    • Lay the washing machine on its back.
  2. Kenmore 110 Series Washing Machine Drive Belt Replacement: 步骤 2 中的图像 1,3 Kenmore 110 Series Washing Machine Drive Belt Replacement: 步骤 2 中的图像 2,3 Kenmore 110 Series Washing Machine Drive Belt Replacement: 步骤 2 中的图像 3,3
    • Using a 5/16" socket wrench, remove both screws from the belt cover.
    • Remove the belt cover from the washer.
  3. Kenmore 110 Series Washing Machine Drive Belt Replacement: 步骤 3 中的图像 1,3 Kenmore 110 Series Washing Machine Drive Belt Replacement: 步骤 3 中的图像 2,3 Kenmore 110 Series Washing Machine Drive Belt Replacement: 步骤 3 中的图像 3,3
    • Using a 1/2" socket, remove the bolt securing the drive pulley.
    • Remove the drive pulley and belt.
    • When installing a new belt, wrap the belt around both the motor and drive pulleys before reinstalling the drive pulley.
结论
18等其他人完成本指南。
Robert Trout
于09/26/12注册
1,234 声望
创作了5篇指南
团队
Cal Poly, Team 15-43, Forte Fall 2012 Cal Poly, Team 15-43, Forte Fall 2012 的会员
CPSU-FORTE-F12S15G43
5 名成员
创作了12篇指南
9条评论
What would be reason that rinse cycle doesn't spin and it leaks
lauraleahenquinette - 回复
Will the drive belt make a clicking/grinding noise? I originally thought it was just a slipping noise, but empty it does make the grinding noise.
Gary Long Jr - 回复
It makes noise like it’s working but it’s not grabbing anything
Ricardo Vallegos - 回复
You can change your gearbox
Adarsh Pandey -
What belt type should I use for a 110.24642300? I cannot find its belt online.
Elizabeth Glenski - 回复
添加评论
浏览统计数据:
过去 24 小时: 19
过去 7 天: 120
过去 30 天: 696
总计 128,151
