Use this guide for replacing faulty key switches on the KEMOVE Snowfox 61 mechanical keyboard.
A mechanical keyboard with a faulty switch causes multiple key inputs to be pressed or not respond. This occurs when grime build-up is left for too long in the keyboard, causing some keys to no longer function, requiring replacing the keys completely or cleaning the board.
No special skills are required.
Any Gateron switches will work, such as red, blue, green, etc.
Do not leave in sunlight or use a hairdryer because the heat might cause the plastic to warp or bend.
Take out the keycaps.
Ensure that the keycaps are separated and facing down.
Let the keycaps dry for 45 minutes.
If you cannot wait for 45 minutes, you may use a microfiber cloth and hand dry the keycaps. But be thorough in the cleaning process as there may be excess water inside the keycaps.
