跳转到主内容
Kawasaki Ninja 300 Seat Replacement
你所需要的
  1. Kawasaki Ninja 300 Seat Replacement, Seat: 步骤 1 中的图像 1,3 Kawasaki Ninja 300 Seat Replacement, Seat: 步骤 1 中的图像 2,3 Kawasaki Ninja 300 Seat Replacement, Seat: 步骤 1 中的图像 3,3
    • Locate the bolt holding the side seat cover in place and remove it using a 4mm hex key.
    • Make sure to also remove the bolt's washer.
  2. Kawasaki Ninja 300 Seat Replacement: 步骤 2 中的图像 1,3 Kawasaki Ninja 300 Seat Replacement: 步骤 2 中的图像 2,3 Kawasaki Ninja 300 Seat Replacement: 步骤 2 中的图像 3,3
    • If you're working in cold conditions, be careful not to break the side seat cover.
    • Reach under the side seat cover and firmly pull it out to unseat it from its rubber clips. There is one at the rear of the cover and two at the front.
  3. Kawasaki Ninja 300 Seat Replacement: 步骤 3 中的图像 1,3 Kawasaki Ninja 300 Seat Replacement: 步骤 3 中的图像 2,3 Kawasaki Ninja 300 Seat Replacement: 步骤 3 中的图像 3,3
    • Locate the seat bolt and remove it using a 5mm hex key.
    • It's best to use the longer end of the hex key, as the shorter end won't quite fit.
    • Repeat these steps on the other side of the motorcycle before continuing on to the next step.
  4. Kawasaki Ninja 300 Seat Replacement: 步骤 4 中的图像 1,3 Kawasaki Ninja 300 Seat Replacement: 步骤 4 中的图像 2,3 Kawasaki Ninja 300 Seat Replacement: 步骤 4 中的图像 3,3
    • Grab the front section of the seat and slightly lift it up and back to remove it.
结论
2等其他人完成本指南。
Craig Lloyd
于02/10/16注册
35,519 声望
创作了82篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 50
过去 30 天: 176
总计 12,302
