跳转到主内容
Katadyne Hiker Water Filter Cleaning
你所需要的
  1. Katadyne Hiker Water Filter Cleaning, Katadyne Hiker Water Filter Cleaning: 步骤 1 中的图像 1,1
    • Remove the "snap fit" guard by pulling directly away from the filter body.
  2. Katadyne Hiker Water Filter Cleaning: 步骤 2 中的图像 1,1
    • Remove the pump handle by pulling it completely out of the shaft.
  3. Katadyne Hiker Water Filter Cleaning: 步骤 3 中的图像 1,3 Katadyne Hiker Water Filter Cleaning: 步骤 3 中的图像 2,3 Katadyne Hiker Water Filter Cleaning: 步骤 3 中的图像 3,3
    • Use the pump handle to remove the filter cap.
    • Place the horizontal groove of the pump handle depicted in image 1 onto the filter fins.
    • Press the pump handle firmly against the fins and turn the filter counter clockwise.
    • Once unscrewed, remove the filter completely from the body.
  4. Katadyne Hiker Water Filter Cleaning: 步骤 4 中的图像 1,3 Katadyne Hiker Water Filter Cleaning: 步骤 4 中的图像 2,3 Katadyne Hiker Water Filter Cleaning: 步骤 4 中的图像 3,3
    • Only perform this step if solid particles are evident on the outside of the filter.
    • Lightly brush the entire filter with a soft bristled toothbrush under running water.
  5. Katadyne Hiker Water Filter Cleaning: 步骤 5 中的图像 1,1
    • Replace the filter inside the filter body and screw clockwise until tight.
  6. Katadyne Hiker Water Filter Cleaning: 步骤 6 中的图像 1,1
    • Lubricate the pump handle O-ring extensively with the Katadyne lubricant (sold with pump).
  7. Katadyne Hiker Water Filter Cleaning: 步骤 7 中的图像 1,1
    • Replace the pump handle inside the pump handle shaft.
  8. Katadyne Hiker Water Filter Cleaning: 步骤 8 中的图像 1,2 Katadyne Hiker Water Filter Cleaning: 步骤 8 中的图像 2,2
    • Replace the "snap-fit" guard by pushing directly toward the filter body.
结论
If difficulty pumping persists, a new filter is required.
另外一个人完成了本指南。
Dylan Carey
于02/24/15注册
130 声望
撰写一个指南
团队
Cal Poly, Team 24-6, Green Winter 2015 Cal Poly, Team 24-6, Green Winter 2015 的会员
CPSU-GREEN-W15S24G6
4 名成员
创作了15篇指南
一条评论
wow. this is very helpful post.
thanks for nice guide line..
plz cheak out this—https://waterfilterhub.com
Kenny J. Jackson - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 13
总计 687
